I lost the startup disk to my Brother wireless printer, MFC-J270w. How can I now connect it to the new HP laptop I bought?
SOURCE: LOST START UP DISK
you can download the driver and install them from HP.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1146336&lc=en&cc=us&dlc=en&submit.y=6&submit.x=7&lang=en&cc=us
this link should get you to the C3150 page, you will need to select your operating system since you did not advise above. the it will tak you to the drivers page, save the download to your computer and install it.
SOURCE: brother printer mfc 240c
no. you should buy a mfc 440cn / 465cn or better -if wireless- a mfc 865cw
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
SOURCE: cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
