SOURCE: cord replacement on skill saw model # 5007nb
the cord set you need is 664463-0, the wire guage is 2x14x8 SJ any repair shop should be able to help you with the proper wire guage cord for this tool. The installation is really easy after removing the handle half
SOURCE: Where do I buy a power cord for a Makita circular
You can go to www.eReplacementParts.com. I've have pretty good luck finding items. Make sure you have the model number available. Good Luck!
SOURCE: how do i replace my
is the spring stretched?? there are 2 holes one in the lower guard and one in the upper guard assembly towards the back that you have to put the bend of the spring in
SOURCE: Instructions or diagrams on how to replace a power cord
saw just quit,fairly new ,light comes on ,so theres power
SOURCE: I have a makita 5997nb
The cord ... or the switch ... or the brushes.
You will have to take the handle apart to access the end of the cord and check the switch. Test your cord with the ohm function of a volt/ohm meter.
Thanks for your question and good luck with your repair.
