STAYS AT A BLACK SCREEN THAT SAYS MISSING OPERATING SYSTEM
On my Dell Insprion Windows 7, I have got "Missing Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
The true cause of "Missing Operating System" error is explained in the article:
http://www.prime-expert.com/articles/b12/fix-missing-operating-system.php
It also contains detailed instructions how to fix this error.
Reset with F11?
SOURCE: Error loading operating system
Press the F2, and laptop will go to the bios where you will be able to change the boot order from the hard drive to the optical drive.
SOURCE: operating system not found media test failure will not reboot aspire 3680
hi..try to remove unplug or plug in the Hard Drive,, if cant work you or nothing happens you need to re-place the hard drive.about files theirs nothing ways to recover the files if the Hard Drive is totally defective..Thanks..and GOOD LUCK...^_^
SOURCE: PXE-E61,PXE-MOF,OPERATION SYS MISSING
I have three kids with the same Acer Aspire 3680-2681. All in over a year have had this. The first sat til we gave up and just tore apart. Put back together, it worked, better. Nothing done. The second, a couple months later, we just took out the hard drive, made sure it was in the correct and full way in, and it worked. This week, the third, same problem, same solution, Took out the hard drive, put it back in snuggly and it worked. It has two screws that SEEM to hold it in place but it does slip out. BEFORE you do all these other ms-dos things and other crazy time consuming file losing pictures forever gone things, try this, and bring a can of compressed air, get the dog hair and dust out while you are there.
It seems to be a small engineering thing with the screw placement and holding of the thing securely in my humble opinion.
SOURCE: Aspire One Netbook , Blank Screen and nothing loads?? Linux
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena76
SOURCE: When i turn on my
It sounds like it is trying to boot from a network. Enter the bios by hitting the delete key during boot. First see if your hard drive is recognized. If not yours is bad. If it IS listed check the boot sequence and make sure your hard drive is first, or CD first HDD second. Save and try again. Hope this helps.
