I checked the water valve...OK. The dish washer fills during initial prewash and wash cycles, drains ok, but then at the start of each rinse cycle, there is a quiet period when unit should be filling with water (to rinse), but nothing happens. Then it goes into its rinse cycle, pump runs, but there is no water. Since water valve is OK, I figured it was bad circuit board, so I just replace with brand new circuit board controller, and the dishwasher does the same thing.
SOURCE: Fills with water, sounds like it starts to pump water then stops, then start again
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
SOURCE: dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
SOURCE: WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
Did you ever solve this? Our dishwasher won't fill after the prewash.
