Palit Microsystems Palit GeForce 8400GS Super+ DDR3 VGA/DVI/HDMI Low-Profile PCI-Express Video Card NEA8400SFHD06, (1 GB) PCI Express Logo
mohammadsoleiman Posted on Apr 01, 2012
Download GF8400GS 512M DDR3 32B(TC)CRT DVI HDMI
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Apr 02, 2012
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
3230
Points
62
The driver is available at geforce try to search on support of their site you can search in google for their site
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1617
Points
Anonymous
Level 1:
  • Posted on Oct 25, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1617
Points
1 Related Answer
ghost2233
Hans Pedersen
  • 3606 Answers
  • Posted on Feb 26, 2013
SOURCE: Download GF8400GS 512M DDR3 32B(TC)CRT DVI HDMI
Hello the driver can be downloaded here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
By selecting geforce
Geforce 8 series
Select 8400GS
And your windows system.
Then the driver can be downloaded.
You have to reboot the pc, when the driver install is done.
Good luck
21helpful
Geforce 8 series
Select 8400GS
Good luck
2answers
How do i active hdmi on eah3450, i cant get picture
This card only has a VGA, S-Video, and DVI output. There is no HDMI output. It is made by ATI, and only compatible with motherboards that have an Intel CPU. If your Processor is an AMD, this graphics card won't work with your computer.
I have a Pioneer VSX 52TX receiver. I would like to connect the Playstation 3 using HDMI to the receiver and then output to the Panasonic Viera TC-P58V125. The receiver does not have HDMI but does have a...
Hello a1v.... You will need a DVI to HDMI adapter, available at Radio Shack, Walmart, on the internet. This item is usually about $6.00.
Joe
Thanks for choosing Fixya!
I lost my driver how can i install it?
You can get drivers for ATI products at http://www.amd.com/us/Pages/AMDHomePage.aspx
If you tell me what operating system you're running (and whether or not it is 64-bit), I can give you more specific information.
1helpful
I have a Panasonic TC-P50X1 and want to connect my laptop to it. What should I do?
If your laptop has a DVI or HDMI output, then the solution is as easy as buying a DVI to HDMI cable, or simply an HDMI cable, because your TV set uses HDMI as an input. If you have a Macbook, there are Displayport to HDMI cables/adapters available.
However, if your laptop only has VGA output, then you must buy a converter. Why? The VGA output available on almost any laptop is an analog signal. Buying simple cable adapters will not make your TV (which reads only digital signals) read the analog VGA signal.
2helpful
4answers
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
ATI Radeon HD4850 512MB GDDR3 with
you have to go into control panel hardware and sound, now click on sound, you will see speakers with a green check next to it. on top you will see HDMI enable those and hit test button. this is part of device no worry bout bios or motherboard. Just make sure you use the adapter that came with the video card it will only work with the supplied adapter. Not a dvi to hdmi cable. this will work. i hope this helps and good luck. I can coach you more but i am not sure of your operating system. i was coaching you using vista.
Sony trinitron KV-30HS420 HDMI
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Top Palit Microsystems Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Palit Microsystems Computer and Internet Expert? Answer questions, earn points and help others
