Question about Video Game Consoles & Games
Ps3 afterglow dongle not working?
I've only had my ps3 afterglow controller for about two weeks now. after working perfectly for the first couple of days, i cannot get the dongle, the part that actually plugs into the USB of the ps3, will not light up. so i cannot connect my controller. Any suggestions?
Mathias Einem Mathisen
Chilly100 do u have to open the controller to access the reset button??
Posted on Apr 07, 2014
4 Related Answers
Anonymous
  • 12 Answers
SOURCE: PS3 does not detect controller even with a USB cable
hold down the ps button. and then connect a usb cable .
Posted on Sep 04, 2009
Anonymous
  • 50 Answers
SOURCE: dial up (3g dongle) internet (lan) sharing on vista
the ps network will not recognize dial up.. you need to update to broadband... sorry
please rate me...thanks
Posted on Jan 12, 2009
Big Hev
Dennis
  • 64 Answers
SOURCE: PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
Posted on May 19, 2009
Anonymous
  • 3 Answers
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Posted on Jul 09, 2008
How do I get my PS3 afterglow controller with a chargeable battery installed to connect to my PS3 system. (afterglow controlder does not take AA batteries).
Afterglow AP 2 has a flat nickle battery
upgrade your controller
i take it yours is not a wireless
PS3 wireless afterglow controller uses aa rechargable
Mar 31, 2017 | HOW Video Game Consoles & Games
Afterglow wireless controller. Do I need the dongle to sync it to the Play Station?
Yes. You may be able to get another one but not 100% sure if it will sync to a different dongle. I would guess that it will work. Green Afterglow AP 2 Wireless Controller Receiver Dongle PS3 Playstation 3...
Aug 20, 2015 | Video Game Consoles & Games
Where is the reset button for the afterglow AP.2 wireless located
There is not one. The Afterglow AP2 requires a dongle that plugs into one of your available USB ports in the system. Without it, it is just a glowing paper weight. Setup: Controller=transmitter, dongle=receiver. Read the box if you have it. If it says something like (2.5 htz) then it isn't bluetooth compatible.
Oct 05, 2014 | Sony Playstation 3 (PS3) Console
PS3 Afterglow wireless controller not working
Call the company and they'll send another USB part
Apr 07, 2014 | Video Game Consoles & Games
Controller will no longer sync to ps3
check batterys try with new ones, dont buy the cheap ones
Jan 09, 2012 | Pelican PL2045 XBOX AFTERGLOW PRO...
Can't connect orb controller to ps3
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect. Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
Jul 27, 2011 | Intec PlayStation 3 Turbo Shock III...
My new afterglow controller won't sync but turns on, it is wired.
If by not syncing you mean it flashes the whole ring when you plug the controller in the USB and won't identify? If so I think the problem may be that you have other USB devices plugged in at the same time. Unplug all the USB and plug the controller in by itself. I've had issues with this for awhile myself. I had a bluetooth and another wireless kb/mouse. So I unplugged everything tried it by itself and it seems to identify perfectly.
Conclusion: Unplug all the USB devices and plug the Afterglow 360 controller by itself and that should solve the problem. =)
Dec 01, 2010 | Microsoft Xbox 360 Controller
Video Game Consoles & Games Logo
7,094 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
