Paragon 7007-00 Electromechanical Indoor 7 Day Timer Logo
A
Anonymous Posted on Mar 31, 2012
Is there a digital replacement timer for the Paragon 7007-00 model
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Oct 05, 2009
SOURCE: Paragon timer parts
electricalexpeditors.com
Anonymous
  • 52 Answers
  • Posted on Dec 30, 2009
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Anonymous
  • 22 Answers
  • Posted on Jan 21, 2010
SOURCE: I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Anonymous
  • 52 Answers
  • Posted on Jan 27, 2010
SOURCE: paragon timer part
visit electricalexpeditors.com
we sell replacement parts
leave all info on the contact page
thank you
A
Anonymous
  • Posted on Dec 23, 2010
SOURCE: I need trippers for an
I don't recognize Paragon TC-2.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic cross reference does not have that model number either.
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Paragon sent e-mail last month saying they were no longer making timers and parts, except for defrost timers. Your water heater timer is not defrost timer.
Here is a wide selection of water heater timers, electro-mechanical and digital:
http://waterheatertimer.org/Boxtype.html
Manuals and wiring diagrams are shown for most products on page.
I recommend simple 240Volt Intermatic WH-40 for price and reliability. Drawback is minimum 1 hour on-off.
Or Intermatic T-101 for 120Volt heater or T-104 for 240Volt heaters sold at Lowes.
Intermatic trippers and motors are available and interchangeable, and are made of steel.
Some new timers are made with plastic parts:
GE 15207 is universal 120V 240V and sold at Home Depot.
Tork has new universal electro-mechanical timer, TU-40 for 120 and 240 applications
I use GE 15070 in-wall timer from Home Depot for my water heater because I change times frequently and try to shave every dollar:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
Add a comment if you need more help.
You can also take advantage of fixya phone support.
Fixya expert will walk you through any problem for a price.
Model 4003 00 timer
There are no replacement motors for paragon series.
Replace with 120 volt Intermatic T103 timer or T173 skip-a-day timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://waterheatertimer.org/Buy-T100-series-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
How tio wire a tork model ejwt timer
Tork EJWT is percentage cycle timer that was formerly manufactured by Paragon and sold as the Paragon E500 series interval (cycle) timer
Copy following link for clear Tork EJWT wiring illustration
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle-timer
1helpful
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
I need a replacement mechanism for a Paragon 24 Hr timer control Model 4004-71M.
1) Paragon is no longer making timers and parts except defrost timers.
4004-71M is not defrost timer.
2) Manual shows 4004-71M is DPST 40 amp 240Volt timer.
4000 series is 24 hour repeat timer
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
3) To buy replacement timer, Intermatic crossover guide shows T104M used for pool and spa controls and to replace timer mechanism
T104M at amazon
http://www.amazon.com/Intermatic-T104M-Mechanical-Mechanism-208-277/dp/B001DNYMV6
4) Or you can buy T104 with Nema1 indoor box, or T104R with Nema3R outdoor box
Googel search model number for vendor
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
5) How to wire T-104
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
Hello I need to replace a paragon model 4003-0 can you tell me what is compatable to this model? thanks maury
As you probably know, Paragon is no longer making timers and parts except defrost timers.
4003-00 is not a defrost timer
4003-00 is DPST 120Volt timer 24-hour mechanical timer
Paragon timers and manuals
Intermatic cross reference shows that T-103 is replacement for 4003-00
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T-103 has 120Volt clock motor and can control 1 or 2 - 120V loads or 1 - 240Volt load
NEED TO REPLACE A PARAGON MODEL 4001 24 HOUR TIME SWITCH WITH KNOCK OUT FOR CONDUIT CONNECTION ON TOP
Paragon 4001 is 120Volt SPST indoor timer.
I've never seen knock-outs for these timers on top because the timing mechanism is in the way.
Turn timer sideways, the timing mechanism still works.
geno_3245_78.jpgTimer flipped 90 degrees so KO is on top
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
1helpful
Need a programing Manual for a Paragon electronic timer, used for bells.
Paragon 4000 is a mechanical dial-type timer
You probably have Paragon EC4000 digital timer:
Single channel, NO, NC contacts, SPST with 5 poles or SPDT with 8 poles.
To identify your timer: Paragon 4000-7000 series
If you have EC4000, the following pdf files are helpful
EC4000 Sale sheet
EC4000 Programming
Top Paragon Hardware & Accessories Experts
john h
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
