Washer leaks water on floor. I think the drain must be stopped up with lint, pet hair, etc.
SOURCE: washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
SOURCE: Frigidaire affinity not draining
The problem is that on the infeed side of the pump there is a catch/filter in the Hose/boot that will catch lint and coins (LOTS OF COINS) and will not allow the water to flow through to the pump. This will stop the cycle and prevent the tub from spinning and the basin will not drain.
to fix this turn your washer over and access the pump from the bottom. the boot can be disconnected from the wash basin with a phillips screwdriver, reach in the boot and pull out the plastic catch and empty the debri, reinstall the the catch after cleaning it and put the boot back on. Set your machine back upright and conncet all the hoses and plug it in. It should work. This is a easy job but it will take an hour or so.
SOURCE: Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
SOURCE: lint filter/can't find
THERE SHOULD BE A TRAP DOOR EITHER RIGHT INSIDE THE FRONT DOOR OR ON THE TOP OF THE UNIT MORE LIKELY RIGHT INSIDE THE FRONT DOOR
