Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wfw9640xw00 won't turn on
Posted by beads_chili on
mohsen
    New Friend:
My whirlpool aquasetam washer get fault code f23?
Posted on Jul 25, 2012
5 Related Answers
Juggerbot
  • 60 Answers
SOURCE: control locked light is on on my whirlpool duet
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Posted on Nov 03, 2011
rickyrt441
Richard Hale
  • 4399 Answers
SOURCE: Whirlpool duet Washing machine won't drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive or spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 11, 2011
Kevin White
  • 1902 Answers
SOURCE: washer won't start.....F70 code appeared It's
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jun 26, 2011
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Posted on Jun 27, 2011
caroldon
  • 17130 Answers
SOURCE: whirlpool duet GHW9100LW won't start,
Good job. Sure this sharing was good to be noted though we need to start by checking the door switch to contact for the machine to initiate.
Regards
Posted on Oct 05, 2011
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Drum won't turn
Remove the top to see if the belt is still on.
Nov 23, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer won't get off control lock
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Washer won't start.....F70 code appeared It's a Whirlpool Duet
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
813 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
