When I print my telus bill the font is very small, hard to read.. (I wear glasses). When I print a copy of the bill from PDF , the font is larger ??? When printing from thr internet,ie: recipes, if I don't adjust the font to medium, it will print very small as well. I'm very baffled in how to fix this problem !!!!!! HELP !!! Todays date March 31ft 2012
Which browser are you using? Internet Explorer? Mozilla Firefox? Opera? Google Chrome? Safari?
If you are using internet explorer: Click Tools/View/Text Size and change it.
If you don't see tools at the top of your browser on a line that says File/Edit/View/Favorites/Tools/Help look for tools over on the right then click it and select Toolbars, then select Menu Bar and it will stay at the top of the browser so you can just click Tools/View/Text Size
SOURCE: How Do You Make The Font Bigger On The Google
Are you using Internet Explorer? If so you should see a "100%" in the bottom right hand corner. Click on that and it will change to "125%". This is the magnification level of web pages and can be changed all the way up to 400% or a custom size. Easiest way to change sizes.
SOURCE: adjust font size DPI to make default as 120 DPI
go to settings and set the display settings .
SOURCE: text size must be about
You can change the size of the text by going to the Start menu, then Control Panel. Click on Display, and then from there you can change the size of the text. It increases the DPI of the text so that it's larger.
SOURCE: change the font on my
If you are running windows 7 then go to "Control Panel - Appearance and personalization - Display" and select the font size you like. Vista and XP are very similar.
