I'd like to be able to share files between my computer and my cellphone. The cell phone has Bluetooth and I know how to turn it on and use it, I just can't figure out how I can turn on the Bluetooth for the computer.
Is the computer Bluetooth capable and does it have bluetooth software installed? Most times there will be a switch on the computer to turn on bluetooth or you'll have to hit a sequence of keys.
If there is no bluetooth installed or it is not bluetooth capable, buy a usb bluetooth adapter and plug it into one of the usb ports. It will come with software and drivers.
SOURCE: switch on bluetooth
is your laptop os is vista? bring your mouse cursor on top of your screen and the menu will popup to enable the bluetooth
SOURCE: how do i replace the hard drive in my dell
hello
you can get help from this youtube video regarding replacement of hrad drive.
http://www.youtube.com/watch?v=yQeHCjN3ods
hope this helps, if so do rate the solution
SOURCE: mouse pointer is frozen on dell inspiron m5030
Thank you the Fn and button to the right of F12 enabled my laptop mouse. Appreciate the tip.
SOURCE: Hello, My function key on Dell
http://support.dell.com/support/edocs/systems/insm5030/en/sg/sg_en.pdf PAGE 30
You have to go to (winkey)- xto get to the Windows Mobility Center and in the function key row, select Function Key instead of Multimedia key. This should reverse the Fn problem.
SOURCE: How to disable my touchpad
You can find some instructions on disabling the touchpad herehttp://www.labnol.org/software/disable-touchpad-on-laptop/14052/
and this link has a piece of freeware called TouchPad Pal which allows you to disable the touchpad while you're typing (which should be the only time it gets in the way really)
http://download.cnet.com/TouchpadPal/3000-2084_4-11143760.html
Hope this helps!
