How do i remove the back so that i can replace a projector lamp?
The lamp on this is located (should be) on the front behind the large removable plate beneath the front screen unit.
with that removed and set unplugged you will see the lamp door--remove it and take the lamp out.
I would suggest you look on You Tube as dozens of these sets have start to finish VIDEO instructions for this process.
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
SOURCE: I have a 65 inch mitsubishi and when I got to
not the lamps,the power supply or the convergence amps have failed. i would call a servicer
SOURCE: Have a 52 inch Mitsubishi TV. Just replaced the
Call Mitsubishi the chassis needs to be rebuilt on this set they have been paying for the parts but you will have to pay the labor.
SOURCE: how do you replace mitsubishi tv lamp number
http://www.youtube.com/watch?v=VVAAO25Zing
The above link will give the video how to replace lamp in your TV
