Lost service guide. need code to enter on remote control to begin service and alignment procedures. not convergence. need to realign factory set green marix.
SOURCE: Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
SOURCE: Panasonic PT-47WX53G Projection TV - convergence problem, can not align completely
I don't know why that guy told you to replace your "DC" board (that is the one you mean, right?) More likely than not, it's your convergence amp integrated circuits (ICs). I had what I think was the same problem (on the same exact model TV) you described, and I looked around alot of blogs and DIY websites, and this seems to be the most prevalent root behind these convergence problems. I ordered the two chips for twelve bucks (for both), spent a few extra bucks (like $35) on some electronic tools / solder supplies, and followed procedures laid out here at http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html, as well as paying strict attention to the service repair manual (which you said you already have?). The result? No more convergence problem, and I saved myself around $400 - $550 over having it done by a professional.
Seriously-- I bet this is the culprit. Just make sure if you're gonna do this that you FIRST check the six resistors (located at spots D-7011 thru D-7016) to make sure there are none burnt out / opened. It may be that one of those is fried also / instead. Since they are far easier to replace, it's good just to rule them out first.
And by the way, just FIY, when I did this I had kept the TV unplugged for about two weeks first, cuz I wanted to make sure all the capacitors were discharged and safe. Did I need that much time? Maybe not (some have said a few hours is sufficient), but I was also primarily concerned about the Flyback Transformer and its wires, which have the highest voltage (up to 30,000 volts) and can hold a charge pretty long. And I'm still here to write about it. So, check out the link, and see if you'd like to try this yourself, as well!
SOURCE: Adjusting the convergence after replace convergence chips
Hello fmnii,
Believe it or not the easy part was the replacing of the convergence amplifiers. Now for the hard part, static and dynamic convergence of the TV. To do this, what I usually do is not trust the onboard cross-hatch and alignment patterns, for this I use a signal/pattern generator to create the cross-hatch and alignment patterns. I follow the static convergence instructions first, and then the dynamic convergence instructions. This process taks about 6 - 12 hours (Yes 6 - 12 hours) if done correctly. I say use the instructions because each TV set is different. It sounds like you have your static convergence well in hand and you just need to do the dynamic.
If you can, try to get a signal/pattern generator (I use the VA62A).
I wish you well,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: Green Convergence on a JVC 56" rear projection t.v.
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
SOURCE: JVC AV48WP74 Service mode
Press SLEEP TIMER and, while the indication of (SLEEP TIMER 0 MIN) is being displayed.
press DISPLAY and VIDEO STATUS on the RC simultaneously. Exit: EXIT.
