No sound on my '03 lg plasma flatron tv., model : DU-50pz60
Posted by meleane48 on
SD Tech
    Top Expert:
  • 14,553 Answers
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Posted on Apr 01, 2012
5 Related Answers
Anonymous
SOURCE: LG Plasma TV model #DU-42-PX12X
try contacting LG see if there is a backlight if there is that is most likely your problem
Posted on Aug 16, 2007
TODDAS
Todd Hill
  • 433 Answers
SOURCE: My LG Plasma television DU-42PX12XC had a loud pop
sounds like blown cof ic's
Posted on May 07, 2010
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: lost half of picture
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
Jerry G.
Posted on Jul 16, 2008
Anonymous
  • 822 Answers
SOURCE: The picture is gone, black screen only
check inverter and power supply.
Posted on May 30, 2009
Anonymous
  • 25 Answers
SOURCE: lg tv modle DU-37LZ30 on off indicator light is
Most likely a power supply problem. I recommend taking this to a certified technician and having them look at it.
Posted on Nov 05, 2009
My 42' LG plasma tv model number 42PC1DA-DU monitor is not show but the sound is working. What should I do?
In this case, the defect is in Y-SUS PCB, change it and adjust the voltage that are specified
on sticker attached to plasma module
4helpful
LG Flatron Model RT-29FA30RX Manual. Where can I find one please
the screen of my tv is widened and i want to know how to readjust it.....
4helpful
2answers
Your tv contains protection circuitry that would shut down the tv if the ymain was out. If the ymain had blown, you'd have no sound and just a flashing standby light. My gut tells me you need to replace the Power Supply Board (PSB). I've seen this before and after spending too much money trying to diagnose a ymain failure, I was surprised to learn that when you have sound but no picture, the psb is a gonner. Try ebay, shopjimmy.com or discount-merchant.com for a replacement.
Good Luck!
I was just wondering if I could make my LG remote, 6710V00116F, into a universal remote?
A universal remote has a special chip in it that allows it to change the codes for other devices. It should work only on these tvs: DU-42PX12X, DU-42PX12XC, DU-42PX12XD, DU-42PZ60, DU-42PZ60/H, DU-42PZ60H, DU-50PX10C, DU-50PZ60, DU-50PZ60/H, DU-50PZ60H
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
2helpful
2answers
have a du42py10x and i have no pic or sound take the back of and only 2 littel ligh on bottom com on
3helpful
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
2helpful
LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Televison & Video Logo
Top Televison & Video Experts
Ekse
