Question about Fujitsu Siemens PlasmaVision Computers & Internet
My fujitsu plasma tv has sound but no picture
Posted by lcortez40 on
chad_s508
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Check connections most likely culprit is a blown fuse on the screen mainboard very easy to replace but must be soldered unless you use a little bit of copper wire twisted and rolled up to cover both ends of the internal fuse then stick it down with insulation tape but do this at your own risk
Posted on Nov 12, 2013
Troubleshooting a Fujitsu plasma screen. No picture, or audio.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 29, 2015 | Fujitsu Plasmavision 42" TV
No sound on my fujitsu 50" plasma TV
its not hooked up right your cable box or tv manual should show you how, cable audio out, tv audio in left and right
Jun 15, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
Fugitsu plasma has pink fuzz dots through picture
It sounds that the Y buffer or Z sustain board has the fault. Check this link. The site has pictures of faulty plasma screens, along with faulty boards. There is no repair to any of these boards, only can replace it with same type number. Try to find out the faulty board to your TV.
Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name first.
Dec 21, 2012 | Fujitsu Plasmavision 42" TV
Fujitsu 50 inch TV has sound but no picture
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now
Oct 03, 2012 | Fujitsu 50 in. Plasma TV
I just got a new power supply installed in my Fujitsu 50in. Plasma P50XHA4OUS and cannot get the sound to work, we've tried everything, please HELP!
Assuming the power supply is exact replacement and you did not have this before--check the speakers to make sure not turned off.
If using a cable or sat box make sure sound not way down or off both with the set and the box.
Last but not least if sound is there with a DVD---something somewhere is set to wrong position.
Apr 27, 2012 | Fujitsu 50 in. Plasma TV
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
My 50' 2005 fujitsu plasma starts with a few flickering lines and within a few minutes the whole screen is covered is horizontal lines - any ideas?
It sounds to me as though you have a faulty Digital board which can be repaired by Fujitsu.
Please call 0208 731 3432 for further help if needed.
Brads
Jun 10, 2010 | Fujitsu Siemens Plasmavision P55XHA30 55...
Fujitsu plasma tv is on but no picture on screen. monitor screen seems to work as it displays the "video input", but there's no picture
Check all inputs. Are they all dead. Try other signal source. Does antenna input work when connected to known good source?Vide input label being displayed indicates most of the tv is working. You need to determine if you have lost signal in the video input.
Nov 09, 2009 | Fujitsu P55XHA40US 55 in. Plasma...
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Computers & Internet Logo
310 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Erni Mallari
Erni Mallari
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
