SOURCE: CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
SOURCE: CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
SOURCE: YAMAHA CD PLAYER WON'T PLAY
I have a Yamaha CD changer 815RS whose door will not open so that I can change the discs. The discs play and the turntable turns, but I can't open the door to change the discs. Any suggest- ions?
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
SOURCE: it won't play disks and
The mechanical parts are working but the laser pickup assembly is not reading the disc. The possible causes are, dirty laser pickup lens, bad pladder motor, or no b+ to the motor, or worn out laser assembly system. Because of the expense of buying the Bose units I highly recommend a professional service man to work on the item.
