Question about Lenoxx Electronics Audio Players & Recorders
Want to know how to set the time on a lenoxx cr62 radio clock
Posted by julieadobbs on
5 Related Answers
Anonymous
SOURCE: Matsui Radio Alarm CDCR200 set the clock time, lost instructions
Hold CLOCK SET button down, press HOURS and MINUTES until you get the right time, release CLOCK SET button. This radio alarm unhelpful calls the ON/OFF button "STANDBY"! To turn it on, press the STANDBY button so the standby light is on!
Posted on Jun 22, 2010
Anonymous
SOURCE: Set CD Clock Radio for Daylight Savings Time
I downloaded the manual from the Timex website give in a prior post.Here is a link to the manual in PDF: http://www.mediafire.com/?cn1kusjfosx
Posted on Aug 19, 2007
Anonymous
  • 185 Answers
SOURCE: Zenith Redi_set clock radio Z230S
Describe your problem: Depress MONTH/DATE and ALARM1 for 3 seconds and display will show DST 'start' month,week,and date.
Display will show 4F 4.1, alternately flashing
4F = April First week. 4.1 = April 1.That is the old dates for change. What we want to do is to change to the new dates. Once it is done, it will change in the new dates as it did on the
old dates..
Hold down the MONTH/DATE button for 5 seconds, and while pressing the - or down button3 times, until the display shows '3'F2.
3 is month F2 is the week.
=March 2nd week.
You have successfully change the March changeover.
Now for the November change.
Depress and hold MONTH/DATE and ALARM2 after 3 second the display will show DST 'end' month,week, and date.
First digit will be 10 =month. second digit will be L=Last week, and date, will flash alternately.
While holding down the MONTH/DATE press the + or UP button once the display will show 11 (November) and F (first week) and 1 as date alternately flashing.
You have successfully set it for the next 100 years
Posted on Nov 01, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: how do I set the
http://www.retrevo.com/search?q=Lenoxx+Electronics+CDR-190
Page 1 and 8
Basically, hold the time button and adjust the hour and minute; hold the alarm button and adjust the hour and minute using the buttons.
Posted on Jan 15, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: the car I bought recently
You might find your unit here:
http://www.retrevo.com/samples/Lenoxx-manuals.html#Radio
http://www.retrevo.com/samples/Lenoxx-CD-Player-manuals.html
Posted on Jan 18, 2011
Hi !!! my name is carlos and just i bought a rca clock radio rp5420 and i dont know how setup the clock if you know how can i do that tell me how please apreciate your help thanks!! sorry for my bad...
You do not have to set the clock time as a built-in automatic time set system is equipped in this clock powered by 3V (2X AA batteries). All you have to do is to plug this clock for power and current time will be shown automatically. However, the batteries can also be exhausted and it is recommended to replace the batteries every 2-3 years.
But if you want Setting the Clock:
1. Slide the switch /WAKE1/WAKE2/ on the top of the unit to clock position.
2. Press REV or FWD to set the clock time. The time decrements or increments will follow by a faster rate when you press and hold the buttons. The ":" between hour and minute time flashes when you are setting the time. AM or PM icon will also beside the time.
3. Slide the switch /WAKE1/WAKE2/on the top of the unit to original position when finished.
Thanks.
gylacz
Aug 29, 2011 | RCA RP5420 Clock Radio
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
How do I set the alarms -- I've lost my manual
The manual:
http://www.retrevo.com/support/Lenoxx-CDR-190-Clock-Radios-manual/id/22975ci174/t/2/
Hold the Time Button down,
and press the Hour Button,
until the right hour time shows
in the display.
and press the Minute Button
until the right minute time
shows in the display.
Jan 18, 2011 | Lenoxx Electronics CDR-190 Clock Radio
How do I set the clock and the alarm on my lenoxx radio/ipod dock device?
Page 1 and 8
Jan 15, 2011 | Lenoxx Electronics CDR-190 Clock Radio
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Nov 17, 2017 | Lenoxx Electronics CDR-190 Clock Radio
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
Alternating time and radio setting
When the display was doing this to me tonight (I just got the thing, so fat lot I know, huh? I try), I pushed the "OFF" button 2 or 3 times. The OFF button is on the top of the clock, next to all of the alarm buttons. It quit alternating for me.
Mar 02, 2008 | RCA RP5420 Clock Radio
Need help
their is nothing you can do yourself to repair this as it needs a new laser unit but the only thing you can do is take it to tv repair shop and they will fit a new one and get it recalibrated for sorry i couldnt offer you any more help................................
Oct 30, 2007 | Lenoxx Electronics CDR-190 Clock Radio
59 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
