Check the installation manual here
http://lightingworldbay.com/category/hampton-bay-manuals/
SOURCE: where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
SOURCE: wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
SOURCE: I added a light kit to my ceiling fan using the
Soundes like you might have a loose or broken nutral wire(white) in the box where the fan is wired in. check that. If that is all wired right then look at the conections where you pluged in the fan. may be bad conoctors. Let me know. Happy to help.
SOURCE: I am trying to install a universal light kit in a
Remove the fan, attach the blue wire with the black in the ceiling box and your light will work.
Testimonial: "Yep, you are absolutely right! And I was able to remove the cover at the ceiling with no problem. VERY HELPFUL. THANK YOU!"
SOURCE: Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
