My amp cuts off when I turn it up at high volume .... And then back on at a lower volume .. I check the power .... Ground... Ohms... Wiring subs ... What could the problem be?
Problem could be that you need to upgrade your battery, do the "big 3" wiring by a professional. Get a kinetic 1200 or bigger to replace your stock battery, drive your car for 5 or 10 miles, and watch your amp not shut down. People just dont do the big 3, and they think their stock lead acid will hold 13 volts after the power is shut off. LOL. KINETIC.
SOURCE: i bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
SOURCE: Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
SOURCE: fuse keeps blowing when sub volume is turned up
the amp draw rating on the amp is 100 you need to put a larger fuse in, such as a 150 amp, it would be a good idea to go to 0 ga but not needed. you might also want to upgrade your altenator.
SOURCE: jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
SOURCE: i have a jl 1000/1 amp hooke up to 2 12 w6 subs
check your baterry post you need to have them tight i had the same amp and 2 15s L7 the blue light turns on right make sure there not covered in acid corrossion clean them out
