Some games play fine, some shut down my computer. no rhyme or reason to me. all games meet system requirements.
Some games require more processor use, some less.
If the games that cause your computer to shut down feature high resolution graphics or fast 3D rendering, then the problem could be insufficient processor cooling. Once the processor gets overheated, it goes into thermal shut down.
If, while you play, the computer runs hot before it shuts down (check the cooling fan outlet), then these are some of the possible reasons:
-cooling fan blades could be obstructed by dust - cooling fan needs to be cleaned or replaced
-heatsink radiator and / or air outlet could be obstructed by dust - also need(s) to be cleaned
-thermally conductive grease on the microprocessor heatsink could be
partially or entirely dried up - old grease needs to be carefully removed and new grease applied (caution - do not use any kind of thermal grease that contains metallic particles like silver or aluminium - you might short out the processor - only use the kinds which are electrically nonconductive)
of course the problem could be elsewhere, but the above mentioned problems turn out to be a common issue with many laptop computers after a few years use, regardless of manufacturer brand and model, also it could be any of or the combination of any or all of the above problems (obstructed air outlet leads to more dust being deposited on the fan blades, more dust on the fan and outlet leads to processor overheating which leads to thermal grease drying which leads to even more overheating and so on...)
hope this helps somewhat
regards
triarcuate
SOURCE: automatic shutdown problem with my DELL laptop
Sounds like you need more ram,,or your processor is too slow.
SOURCE: dell latitude d610
try changing your keyboard it might be shutting down because of a keyboard error and it seems like your caps lock is acting up a bit i would suggest to try cleaning it first and seeing what you could do about that. If you can log into bios possibly you might be able to turn of the keyboard error check hope this helps
SOURCE: dell inspiron 2200 won't turn on
Let it cool down.. Put it in the freezer(in a plastic bag for 20 minutes with the battery out of it. Then allow it to warm up for 10 minutes. these laptops are not great at playing games because they overheat..you should get an external graphics card if you get this running again..
Heres a link to a place where you can get a better graphics card
SOURCE: Dell 1525 completely shuts itself down eg. when playing Sims 2
This did the trick http://en.kioskea.net/faq/sujet-4281-dell-inspiron-1525-overheating-and-shutting-down
SOURCE: dell d610 caps lock flashes then shuts down
it might be that the laptop is going into either stand-by mode, or hibernate mode, and not actually shutting down, and this flashing of the light is informing you of this.
now, that was one (1) possible explaination.
here's another.
the battery may be defective, or the internal power supply adaptor is going bad.
