I've searched at great length and cannot find a window fan that can be taken apart to enable me to clean it. The Honeywell I have is filthy and it is impossible to get past the louvers to the dirt; all the other fans I have looked at online seem to be the same, utter garbage to be discarded once they are dirty. HELP!!!
SOURCE: I owna honeywell commercial grade
The front wire grating has hooks all around the edge that latch onto the rear grating. You need at least two screwdrivers, blades or thin & stiff shims to pry half the hooks off. Do this by inserting your shims between the front and rear grates, on either side of a hook. Then, lever your shims such that the rear grate warps enough to free a hook and let it pass in front. (Note: this IS difficult; the first hook will not want to clear the rear grate. It helps to have an extra pair of hands, and/or another object to temporarily keep the first hook seperated. It may also be possible to start with three shims and clear two hooks in the beginning). Continue clearing the hooks in a consecutive fashion (they're progressively easier) until half of them are off, at which point the front grate should come off using a little muscle. A couple notes: if available, a plastic shim is preferable over a metal one because it shouldn't damage the nice finish as much (alternatively, wrap your shims in cloth). It is NOT necessary to remove the whole fan cage from the stand to do this. Expect the reverse process to be equivalently challenging. Please wear safety glasses in case your shim breaks or slips. Lastly, good luck if you try to lubricate the shaft. I've tried multiple substances, but day-long blowing continually dries out the lubricant.
SOURCE: Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
SOURCE: Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
SOURCE: How do I get my cool operator fan apart to clean the darned thing
hi! there,
well! no brand and model,anyway the guard fan has a quick clip lockaround the fan blade,be sure to unplug your electric fan before doing this, unlock clip lock then the fan has a quick handy lock knob at the center of the fan observed loosening knob there is direction arrow in loosening this if i'm wrong going counter clockwise,or take the direction indicated marked on top of knob.
pull out the blade and have it clean if this is a plastic or aluminum clean it with water and spounge/cleanser,avoid to distorsion on fan blade if happen this will wiggle when run again be carefull and on the second guard fan still connected to your electric fan,there is plastic lock nut release and pull out the 2nd fan guard,try to clean this with water and cleanser,the motor assembly with control and stand just wipe it out ,don't try to get wet specially the motor,let all dried up before reassemble.reverse the process to eassembly
