Question about Coby Kyros 716829701508 Tablet PC
Will a pny micro memory card work in my coby kyros?
7'' screen
Posted by seth vander band on
Edward Wolf
    New Friend:
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
Posted on Mar 31, 2012
5 Related Answers
Nate
  • 133 Answers
SOURCE: I have a coby Kyros
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Posted on Aug 19, 2011
19ken55
Ken Fowler
  • 426 Answers
SOURCE: There are identical icons in my home screen, how
right click on the icon then select delete (on the extra one)
Posted on Jan 22, 2011
Tyson Gough
SOURCE: my coby kyros won't turn
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
Posted on Jul 23, 2011
Gale Todd
  • 1116 Answers
SOURCE: The screen in my Coby
You must contact Coby first. Here are the various ways to contact them:
Posted on Aug 30, 2011
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: I have a coby Kyros tablet and it's not comming on the sreen is dark and the touch arrow that allows you return to the previous page is a illuminated
It sounds like your screen is damaged or faulty and will need to be replaced.
You will have to contact Coby Support to get this fixed:
[email protected]
General product support and inquires: 800-727-3592
- Monday-Friday (8:30AM-5PM EST)
- Saturdays (9AM-5PM EST)
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Nov 09, 2011
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
Coby kyros MID 7022 wont unlock main screen....swiping only meets halfway then screen goes black..help?
ok try the reset button plug the power cord before you start. look where is the reset and use a small point toothpick .
Nov 03, 2013 | Coby Kyros 7" Touchscreen Tablet
My coby kyros mid7125 is froze on the coby screen how do I unfreeze it
Hold down the the power button for 30 seconds and wait for the tablet to power down. Now turn it on. This is the first thing to try.
There is a tiny reset hole in the side of the tablet you should be able to get a reset out of.
Sometimes, the battery must drain all the way and then the table recharged.
Have you rooted this tablet or used CW recovery on it? Or is this a stock tablet?
Sep 28, 2013 | Coby MID7125-4G model Kyros Tablet...
How do I factory reset my Coby Kyros 1125?
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
Oct 17, 2017 | Coby kyros Tablets & eReaders
MY MICRO SD CARD AND USB DEVICE IS NOT WORKING TO MY COBY KYROS WHAT WE DO TO FIX IT?
Need more information, what usb device? what gives you indication the sd card isnt working, and is it a standard size (2, 4gb)
Apr 16, 2013 | Coby MID80244G 8 KyROS TABLET TOUCHSCREEN...
The charger broke off of my coby kyros tablet
You'll have to send it back plus $15.00 for shipping & handling,the company is something to deal with. My tablet still has not been replaced and I sent it back Dec.3 2012,they've received it too!! They are a mess!!
Dec 23, 2012 | Coby Kyros 7" Touchscreen Tablet
How do you update
Before we begin you will need to have the following ready. ? The Coby Kyros with a battery level of 30% or more, the USB cable and an empty micro SD card with a minimum of 4G. The Micro SD card should be inserted into the Kyros. Start by going to our website www.cobyusa.com to download the zip file to your computer. The file can be found on the main page for the MID7015. It is titled "UPDATE.ZIP". It is important that you do not UNZIP the file.
Once file has been downloaded to your computer, turn the Kyros on and connect the unit to the computer via the included USB cable. At the top of the main page Go to the navigation bar and scroll down. A menu will open with several USB notifications.
Click on the External USB connection. This connection refers to the inserted SD card. A new menu will appear Click on MOUNT. Once complete your computer should recognize the Kyros device. A screen will open and show the Removable Storage drive. If this window does not open, please go to the start menu of your computer and select computer or my computer. There may be several drives shown. Please choose the one that corresponds to the SD card, it should show as empty. Open the drive. Now you may drag and drop the ZIP file into the removable storage drive. This process will take approximately 1 minute to complete.
When complete Go back to the Main Screen of the Coby Kyros Once again go to the top navigation bar and Turn off the USB Storage. Another window will appear with a turn off message. Make sure to click on this as well. Disconnect the Coby Kyros from the USB cord attached to the computer. Then Press the Power button, it will again prompt you to power off from the main screen twice.
Wait 5 seconds. During this time locate the power button and the return button. Press both buttons at the same time. Continue to hold the buttons down until you see the warning triangle and android logo. Once the symbols appear you may release.
Press the return button again. The reboot section will appear. You will use the Home and Menu keys to scroll through this section. The Home key scrolls up and the Menu key scrolls down.
Scroll down to Wipe data/factory reset. Press the return button to select. Scroll down to Yes and hit return. The Kyros will notate the Data wipe is complete.
Scroll down to Apply SDcard and press return The Kyros will notate Install from SD card complete. This will take approximately 1 minute .Select Reboot system now and hit return key
Congratulations you have just updated your Coby Kyros
For more info visit www.cobyusa.com
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 06, 2011 | Coby Kyros 716829701508 Tablet PC
Coby Kyros 716829701508 Tablet PC Logo
580 people viewed this question
Top Coby Tablets & eReaders Experts
Marvin
Marvin
Lawrence Oravetz
Edward Morgan
Edward Morgan
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
