Question about Belling Ovens
Schott ceran cooktop glass replacement
Model number 444445548 top gass boken. Need replacement please. Wher can I get replacement glass.
Posted by Ade Dawodu on
  • Tommy McCay Jun 23, 2012
    did you get this fixed? how much was the replacement glass top?
    Thanks!
Barry
    New Friend:
Hi, cooktop glass replacement can be found at amazon, here: Amazon com Schott ceran glass take a look. Wish you best of luck
Posted on Jan 11, 2015
Bernadette argent
Where and how much is a replacement heat proof glass for a schott ceran main oven door ?
Posted on Oct 03, 2014
5 Related Answers
Mmelton05
SOURCE: Replacing a glass cook top
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Posted on Feb 08, 2008
Anonymous
SOURCE: I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Posted on Jan 04, 2009
Joe Bannon
  • 1514 Answers
SOURCE: I have a [email protected] schott
You need to give the model number to get exact instructions. On most Fisher & Paykel ovens there is a button with a picture of a hand over it. You press this button to take it off auto. I expect if yours is new it will be the same. If you need a user manual you can get one in Adobe Reader format from http://www.fisherpaykel.com.au/customercare/userguide/index.cfm
Posted on Sep 25, 2010
Tre Elkins
  • 643 Answers
SOURCE: Hi, I have Schott Ceran
The switch under that knob is bad. It's called an infinite switch. it runs around 5.00 at partsselect.com
Posted on Nov 11, 2010
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: The Schott glass top is
I will assume you are talking about the glass top on a range..If so they are not cheap..they range from 600.00 to 1,000 for a replacement top.
Posted on Dec 19, 2010
Whirlpool Schott Ceran. I have no instruction book and I find it trial and error to turn it on.Is there a book on line , Richard
I would try to get the manual for you but I would need your Model Number for that so here is the next best thing. Go to this site, http://whirlpool.com/home.jsp then in links along the top you will see OWNERS CENTER if you hover above that tab you will see that Whirlpool has supplied us with all the information we could need. Just click on manuals and follow instructions.
Thumbs up if I helped you!!!
Feedback is greatly appreciated!!
Good Luck!
Jun 15, 2011 | Whirlpool Ovens
Can i install my glass top ceran hot plate directly onto my laminated bench top? Will the glass get too hot for the laminated bench top?
The edges of all cooktops, glass included, just sit on the laminated bench tops without a problem. I have never seen a laminated bench top burnt or melted.
Feb 26, 2011 | Ovens
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Jan 01, 2011 | KitchenAid KEBS177 Electric Single Oven
The Schott glass top is cracked - where can I replace it?
Dec 19, 2010 | Whirlpool Ovens
Glass door to bottom oven has broken. Looking where to find replacement glass. Its black/smoke colored.
Not enough information.
Will need to know the model number and product number.Then repost your question.
Hope this helps.
May 20, 2010 | Ovens
Cannot find the model number of my oven and really need an inner glass seal. the model number is not in the manuel! help!!!!
look just inside oven door just below the cooktop/or look on top and just behind the rear control panel,or on back panel,or in lower pull out drawer of unit its one of those places
Sep 30, 2009 | Ovens
Jan 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jan 09, 2008 | Ovens
Ovens Logo
2,663 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Harrie
Are you a Belling Oven Expert? Answer questions, earn points and help others
