My Beko CA5411FF has packed up :(. It had been making gurgling sounds for a few days before it stopped working. The freezer fan is blowing warm air and the fridge section has stopped cooling. Changed the thermostat to 5 (coolest setting) but the fridge is just stays warm. The frozen food defrosted and had to be chucked away. Can anyone tell me whether it's worth getting an engineer out to check the FF or should i just call it a day and accept that the Beko has reached the end of its lifecycle. It is just over 4 years old. lt would be great to hear from other people who have had similar experiences with their Beko FF.
SOURCE: door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
SOURCE: freezer works, fridge is warm
Your defrost timer seems to be bad. Find it at the bottom of the fridge and turn the knob to see if it activates. If it does then it is bad. If it doesn't activate then your element or thermosat is bad. These parts are not to expensive and you can do it yourself and save some big bucks. Be safe and disconnect power before servicing.
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
