I purchased the DVD player some years ago. It worked fine for some time, then it stopped working. We took it to be repaired, and then it worked okay. But now, whenever I put a disk into it, t just says "Loading" and nothing happens. What should I do?
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
SOURCE: Polaroid portable dvd/cd player PDX
Hello
I
had that problem, the problem is that where you put the disc (the black
Circle) tends to get a bit loose so it moves downwards.
so the distance between the lens and the under surface of the DVD / CD is reduce, so the beam is NOT return to the lens.
The way I fix it is by pulling the black circle EXTREMELY carefully and SLOWLY while you are turning it.
Once
is out, with a toothpick or a needle put a small amount of crazy glue
in the inner walls of the hole that is in the center ( where the pole
of the rotor goes in) this way the hole is reduce.
Wait till it dries, then gently put it back in, it will be a tight fit, IT MOST NOT GO ALL THE WAY IN!!!
By
this i mean that you will see the pole of the rotor go into the hole,
but it most not reach all the way, it should be below the surface. The
distance between the end of the pole and the surface of the black
circle should be THE THICKNESS OF THE BLACK CIRCLE.
The way to know that the distance is right, put in a CD and play some songs, then try it with a DVD.
If it reads no disc it means you inserted the disc to much, pull it out a bit, then try again.
Once it reads both CD and DVD, fill in the hole with a drop of crazy glue, this way the black disc will not move anymore.
One
more thing, I do not recommend to use alcohol in the lens, 'cause some
lenses are now made of polymers non resistant to abrasive, instead use
a cue-tip (cottonete, little pole with cotton to clean your ear)
moistened with bottle water or distiled water.
Note MOISTENED not soaked or wet.
Hope it works for you.
Best Regards
Luis.
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
SOURCE: does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
SOURCE: unlock a Philips portable DVD Player Pet 741/37
It worked for my Philips PET741/37:
1. Power ON the DVD player without a DISC inside
2. Press the skip keys in this order (the keys are under the "disc menu" and "stop"): right, left, right, left, right, right, left (YOU DON'T HAVE TO GO TO SETUP MENU, just do this in the "blue screen".
3. It will show a menu with region, now use the arrow keys to select "region" and change to "test 0" (all regions).
4. Press OK to confirm. Enjoy
Silmara
Testimonial: "Easy and Very helpfull ... Thanks a lot for your help. "
