After replacing the DMD chip, hit the reset button and saw rapid green flashes. Simultaneously pressed menu and input - received code 1-2 then status turned red.
You are not the first person I have seen who replaced the display chip and had fubar after--1,2 is no error found.
You might want to do a little more research: Mitsubishi when changing the optical engine has a procedure so the engine can communicate with the digital circuit in the set--opps!
By the way the reset on the front is only a boot up for the set--set also has a hidden option menu for a hard reset of the entire set to factory defaults.
tried that one?
SOURCE: WD-65833 Flashing Green Light/Will not turn on!
its an easy repair however i would recomend not even attempting the repair without the service manual as the DLP chassis is completely incased and you will need the info just to get the chassis out , That will explain exactly how to disassemble. once disassembled there are 4 100uf capacitors that are causing the problem. If you would like the full service manual for your set let me know and I will post a link where you can get it emailed and they will provide free support to help you do the repair.
