Question about Compaq Computers & Internet
My Compaq Presario X1000 restarts itself when using WIFI
My Compaq Presario X1000 often restarts itself after using WIFI for some time. Before it restarts, the screen turns blue with many lines of message shown for a short time before it turns black and restarts. I cannot read the messages in time. Now I have to turn off (switch off) the WIFI so this symptom will not happen. Disabling the WIFI still gets the same symptom.
Larry Ng
  • Compaq Master
  • 5,970 Answers
Old compaq. LAPTOP,, 14 years old now, Im amazed it even glows at all with CCFL lamps not dead, wow.. its like a musiem piece.
(sorry , grin) (back ground lamps CCFL)
NO OS stated by you , XP, ????? why must helpers beg?
and wifi , (difficult that)
it's not wifi, its just that you use wifi most the time ,SEE? right?
in fact we could remove the wifi module. and prove that.
disabling wifi is airplane mode, (todays jargon) but means the wifi transmitter is now OFF (airplane safe is THAT)
the blue screens tell a lot, and no posted photo of one by you.
sad,
BSODs we call those blue screens of *****
XP love to do that. (even with Bill Gates on stage) LOL
BSOD are hard. Im sure it says 2 words, HALT and DUMP !
here is a list of causes.... for sure 14year old relics (legacy junk)
  1. the main battery inside is bad or shorted, remove it run AC , does it, wow, it does, problem solved in minutes flat.
  2. the Inverter is shorted (CCFL card) and bom, BSOD
  3. bad RAM, BSOD XP fast , try 1 stick at a time.
  4. Bad HDD< can corrupte files and XP BSODS in a blink !
  5. any thing shorted, remove all usb devices yet?
  6. remove extra ram. , unplug CD drive?
all techs know rule 1,
is it hardware or software, (this is alway first after #1 above done)
to do that we open the CD tray, insert our free LIVE LINUX CD
and boot to linux
wow it runs for hours ok, proving what, HARDWARE IS BAD
if Linux fails its bad hardware (running period correct disk)
if linux runs i next do a full HDD test, using the great linux program there to do that.
or take that handy dandy, Compac (now HP) 3 disk install disks
set and load disk one, does that run? ok
even full restore. or does it show HDD errors.? oops HDD is bad.
the BSODs are really what.
it means the PC attempted to run and ******* instruction.
in simple terms, it means a program is corrupted.
or tried to do ******* things with memory.
that is why test test the PC with a boot CD to see if the PC is ok.
see?
mr wifi real.
sure this can short, but if it is removed and it still BSODs
its not this card, its other cards, shorted. or not at all. cards.
we call this mini-PCI slot card.
My Compaq Presario X1000 restarts itself when usin - x1000-1oh4aoqbfnskjh0fvlzvt5hx-5-0.jpg
Posted on Sep 15, 2017
5 Related Answers
Anonymous
  • 94 Answers
SOURCE: presario X1000
Unplug AC
Remove Battery
  • Remove the keyboard, tilt towards you disconnect it.
  • unscrew the screws holding the video card in place.
  • remove video card.
  • clean both rows of contacts on the card. Alcohol & Q-tip
  • get some Contact Enhancer cleaner/lubricant & apply on contacts (on video card)
  • reseat the video card
  • press firmly down on the video card where indicated.
  • put kb back on.
Put battery back in
Attach AC
Fire it up and test
Another TEST
Thump the lid switch- sometimes it gets stuck down.
if that is the case. Apply 1 drop (and only 1 drop) of WD40 on the barrel of the lid switch. It will run down into the switch itself and lubricate the plunger.
Hope that helps
Posted on Mar 31, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: medion laptop
That would be a hard drive failure. Unfortunately the your only option is replacement.
Posted on Jun 20, 2008
Anonymous
  • 50 Answers
SOURCE: compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Posted on Apr 06, 2009
Anonymous
SOURCE: Vaio: switch on the wireless LAN = blue screen and restart!
This can be a driver issue.
I would go to the manufacturer website and retrieve the most updated driver for your wireless card.
Then, go to device manager
Right-click on "My Computer" -> Click on Manager --> click on Device Manager
And uninstall the wireless card. For example, my wireless card name is
INTEL/Pro Wireless 3945ABG Network
After you do that, go to Control Panel and click on 'Add Hardware". Click on "Next" and it should detect your hardware.
After it detects the wireless card, point it to the most updated drivers that you downloaded.
See if that works.
Posted on Nov 30, 2009
Daniel Bakewell
  • 691 Answers
SOURCE: My Compaq Presario f500 series Wont turn on anymore
I would like to help but it sounds like it's over heated and needs a repair guy to look at it
Posted on Jan 11, 2010
I want to unlock my bios pasword on my compaq presario x1000
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Dec 14, 2010 | Compaq Presario X1000 Notebook
Brother gave me a compaq notebook and need admin
Ask your brother for the password. He probably assigned one.
Jul 29, 2010 | Compaq Presario X1000 Notebook
I have a compaq presario x1000, cant figure out how to get the scandisc to work
open up my computer
right click on c drive
go to properties
go to tools tab
click check now
restart laptop and scandisk will run
Sep 13, 2009 | Compaq Presario X1000 Notebook
Wireless can't turn on for Compaq Presario X1000
Are you connected to a network and is the light on laptop lit for wifi?
Jan 23, 2009 | Compaq Presario X1000 Notebook
Blank Screen problem!
perhaps you toggled off the moniter... look on your keyboard for a monitor icon.... it happens alot
Robert
Aug 28, 2008 | Compaq Presario X1000 Notebook
Broken power button
They Have one for sale On ebay if you need..
Look here for your compaq presario X1000 power button bezel
http://cgi.ebay.com/APCL312M000-compaq-presario-X1000-power-button-bezel_W0QQitemZ230260679776QQihZ013QQcategoryZ60265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope it helps.....
http://www.wnycomputerpro.com
Jun 11, 2008 | Compaq Presario X1000 Notebook
Monitor going going gone
Presario X1000 has 3 different ATI graphics boards they use.
Two are 32mb and one is 64mb.
For use with HP Compaq nx7000 and
Compaq Presario X1000 notebooks spare part#
ATI MOBILITY RADEON 9200 w/64-MB memory 336970-001
ATI MOBILITY RADEON 9200 w/ 32-MB memory 336969-001
ATI MOBILITY RADEON 7500 w/ 32-MB memory 336968-001
I have on PDF the service repair manual, I can e-mail it to you or you could try to google it.
Apr 28, 2008 | Compaq Presario X1000 Notebook
My Compaq Presario X1000 doesn't recongize my camcorder via firewire port.
It may be the problem with driver. Your OS may not contain the proper driver.Like in windows service pack 1 do not recognise some camcorders. either upgarde to service pack 2 or download proper driver from manufacturers site
Apr 21, 2008 | Compaq Presario X1000 Notebook
Blank screen on Compaq Presario X1000
Since u said that ur screen flashed and also u said that when u connected an external VGA nothing would display so from these two i can tell you that it is a hardware problem and that too with the VGA card/display card.
Thankyou
Feb 10, 2008 | Compaq Presario X1000 Notebook
Computers & Internet Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
