Casio EXILIM Digital Camera Logo
Anonymous Posted on Mar 31, 2012
If i use a 128 MB card how many pictures will it hold
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Casio Master 102,366 Answers
  • Posted on Mar 31, 2012
Casio Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428743
Points
622693
That depends on the image resolution and image quality. At the highest resolution and best quality you may be able to hold about 30 pictures. At the lowest resolution and least quality you may be able to hold about 1500 pictures.
I have a Nikon coolpix B600 and I can't get it to video more than 2 minutes before it runs out of space. I have a 128mb SD card so it should hold a lot of video.
Your camera should be capable to record video for 30 minutes in a row. The SD card should be more than 4Gb to record 30 minutes. and not 128 Mb.
I think you have a 128 Gb card, if not the card is the problem. 128 mb is really not enough for 30 minutes. It would be just enough for one and a half minute.
2answers
How many pictures will a 14.0 mega pixels camera hold without a card?
That depends on the amount of internal memory, the compression rate, and the type of picture. Do you have a particular model camera in mind?
1helpful
2answers
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Do ultimate allience supports on asus A9250 128 mb?
After checking out your video card it seems that your video card is far outdated for this game. You will just need to upgrade it to a newer model and you should see picture.
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
2answers
How many photos can be stored on a digital photo frame?
I generally depends upon the size of the picture that you are storing and the memory card that in the digital frame.
eg 128 MB photo frame ,would store close to 10 pictures at 8 megapixel resolution
1helpful
Incompatiblity of R300 & Toshiba 2 GB SD Memory Card
Epson Printers & All-In-Ones:
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED Compact Flash 4 GB Secure Digital 1 GB Sony Memory Stick 1 GB MagicGate Memory Stick 128 MB xD Picture Card 512 MB Smart Media 128 MB
These are the Epson tested memory cards that will work, also includes the suported memo capacity..
Hope this is helpful, pls dont forget to rate solution.
3answers
Video card upgrade
Needs specs of your board.. Model number
Type and size of media are compatible
The C-7000 Zoom uses the xD Picture card. The compatible sizes are 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, and 512 MB.
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Casio Camera Expert? Answer questions, earn points and help others
