Question about LG 52SX4D 52" HDTV
2005 lg dlp 52sx4d audio but no video. Worked fine until activated tv guide. Now see a bunch of channels we don't want or need, but the rest are audio with black picture. Thx.
Posted by bwlgas on
SD Tech
    Top Expert:
  • LG Master
  • 14,553 Answers
Call up the menu for the Guide and turn that off.
Posted on Mar 31, 2012
3 Related Answers
Anonymous
SOURCE: the lg 52SX4D dlp tv
HAd the same problem with mine, but was under warrenty, they took it to the shop and had to replace the Engine if you need the specific engine name I can look it up, now the bad news if I would have had to pay it would be over a grand for the part alone.
Posted on Apr 08, 2008
riyad179
  • 19 Answers
SOURCE: how to reset after replacing bulb
mute on remote+ok on tv panel at the same time
Posted on Feb 02, 2009
David Areias
  • 11 Answers
SOURCE: I have a LG 52SX4D
Hi, does it have a component video connection for the green, blue and red cable?
Posted on Sep 19, 2011
My lg 65UF6450 has no TV Guide. It searches for active Channels but finds none. Setting them manually doesn't work either. My satellite TV service is on HDMI2 and works fine, just no TV GUIDE.
I have a TV like yours.
When you hook up an external antennae to pick up over the air channels, the TV will find the channels and display a list.
Your other TV services should come with their own channel guides.
Mar 10, 2016 | LG Televison & Video
Ihave a DLP Projection TV, Model Number 52SX4D. When I try to turn it on, in the operation indicators, the second light from the top flashes and then the TV shuts off?
Hi Brian,
The operation LED indicators on DLP Projection TV's also act as 'Diagnostic Indiactors'.
The flash sequence of these LED's indicate the appropriate fault - you will need to refer to your User Manual which should explain what each flash sequence means.
Generally, most faults on DLP TV's relate to either cooling (fan operation), faulty/expired lamp, or even a loose panel (lamp door etc) somewhere is not correctly secured, causing a micro switch to trigger a shut down.
If you don't have a User Manual, try downloading it from the manufacturer's website.
Hope this helps......
Nov 01, 2011 | Televison & Video
I replaced the lamp for my LG 52sx4d DLP television. The TV still wont turn on and has a red blinking light where the green lamp indicator should be. How do i get my tv to turn back on!
did you get a Philips lamp check that also make sure all the doors are close also you could trouble shoot more with discount merchant
Sep 13, 2011 | LG 52SX4D 52" HDTV
I have an HK AVR 355 system, that worked just fine. Yesterday I tried to hook up a new TV, and ended up taking a few cable out since they were not imoportaint any more and only used HDMI cable. Now when I...
Obviously you removed (or disturbed) something that was really necessary to the DVD's digital audio path. "Doesn't work" is pretty non-specific.
Do a web search for "HK AVR 355 manual" and download it. Then read the part about assigning digital audio sources and speaker configuration setup.
Look at the Troubleshooting Guide part that mentions the Channel Indicator Display (page 33).
Aug 17, 2011 | Harman Kardon Audio Players & Recorders
NO sound on TV Picture fine, sound when watching DVD
check your scart male connecter ends are pushed all the way in.
Jan 15, 2009 | LG 52SX4D 52" HDTV
Lg 52" DLP won't come on.
If its not the lamp it will be the Fan.
Jan 10, 2009 | LG 52SX4D 52" HDTV
LG DLP 52SX4D/Will not power up
Ours did the same, it was the colour wheel in the tv, it was stuck [from dust and smoke] and the tv wouldn't go past that problem.
Jan 19, 2008 | LG 52SX4D 52" HDTV
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
182 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
