Hellow i have a microwave but there is no problem with my micro wave nowwhen i plug it in all works great untill you unplug the microwave it don't heat up no more do you think its faulty it heats up when its pluged in and my food yumm cook well but it dosn't work when turned off its spose to be a smart tec microwave can you help or call me on 310 *** **** name is darard bowsky
SOURCE: Microwave sedems to be working but not heating
We woke up one morning and our microwave had no power. I checked the breaker and outlet they are working. Any help
SOURCE: I have a JVM1603BJ03 space
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: ge micro wave mdljvm
Your magnetron is overheating, causing the magnetron thermostat to open, which kills all power to the oven until it cools back down.
Is the internal cooling fan running when you cook? Are all the air vents clear? If not, the magnetron can be destroyed.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
SOURCE: Micro Wave shuts down
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
I will try and see if I can get an appliance expert to help you, as I am not an expert in this field.
