Need replacement bass units
Monacor SPH-165 work well as replacement woofers for TDL Studio 1s.
If you are wanting original sound, you either need to rebuild the units you have, or buy replacements through TDL http://www.tdl-loudspeakers.co.uk
If it is jsut the foam that failed, there are refoaming kits available, a diameter that is comparable should work fine.
If the voice coil is the issue, you "might" be able to locate reconing kits that include the spider and the voice coil. If it is a matter of windings coming off, you can use adhesive solvents that are used by picture framing shops to release the spider and the surround, and then it is a matter of determining how many turns and gauge of wire was used, as well as direction of wind and layers. I have rewound voice coils before and it can try the patience. But I had a speaker that several different component speakers could not match for the cabinet it was in.
If you try different brands of component speaker, you are more likely going to have a difficult time finding a suitable match as a replacement.
I am sorry but we offer repair solution's but we have no parts resources for any product.
