1. Remove bobbin case 2. Unthread machine 3. Replace needle making sure it is all the way up in needle shaft and tighten screw 4. Set for straight stitch sewing 5. Position needle bar at Center 6.Roll up a towel and gently lay machine back on it. 7. Remove shuttle race ring 8. Turn handwheel SLOWLY toward you until needle reaches it's highest point and travels just 1/16" 9. Point of hook should be directly BEHIND the needle OR At LEAST 1/16" or tad above that measurement. 10. As hook passes needle, it should be slightly ABOVE the eye of the needle If timing seems good at this junction, you can carefully wipe the hook with alcohol on a clean, lint-free cloth (old T-shirt makes good rag) MAKE SURE YOU ARE CAREFUL BECAUSE HOOK POINT EXTREMELY SHARP! ALWAYS SET POWER SWITCH TO OFF POSITION/UNPLUG -- Never panic or toss machine across floor because you can probably determine that it's just a matter of rethreading or a minor adjustment. Hope this helps! Jimmy
