Computers & Internet Logo
Anonymous Posted on Mar 30, 2012
MODEL LT2016U WONT BOOT UP - Computers & Internet
isaac akwarandu
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 20, 2014
isaac akwarandu
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
512
Points
It doing absolutely nothing when i plug in the power cord but the light for the battery comes up
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Mar 30, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1059473
Points
15385
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
HOW TO
Boot up with the function key that opens your BIOS. There s a factory or default BIOS in there. (Do not do this, if you are trying to find the factory settings for Microsoft Operating System as when you first received your PC... they are two different things mate.) To do this, you need to go to System Restore and select the earliest Highlighted Date on the backup calendar display. The PC will go back to that date in time... it will NOT delete your data that you have added since then.
2answers
Primary Master WDC WD1600BEVT-22A23LOCK
You don't have a password? BIOS or Login password?
I got lt2016u netbook Gateway How do i create a Bootable Disk I got usb FLash drive and its 16GB i need to restore it
Most Windows CD\DVD's are bootable, but if you are referring to a USB bootable, then you will need software like : http://www.microsoftstore.com/store/msus/html/pbPage.Help_Win7_usbdvd_dwnTool/
You will have to have access to the Windows install disc to create, and may have to create it on other computer. gl
I install windows vista on my Gateway Lt2016u Wireless Netbook/laptop...and network adapter drivers are missing.
You still need to install the drivers into your computer. You can get all the drivers in the website of the manufacturer.
Look for drivers and download page. Enter the model of your computer and select the operating system that you are running. Install the drivers.
After installing the drivers, make sure that they are all updated to the latest version to make them work to its full potential. You can install RadarSync (www.radarsync.com) - it is a PC driver updater to make your drivers updated all the time.
David
Where can i download Network Controller
Go to the website of the computer's manufacturer to get the driver. After installing all the drivers, make sure that they are updated. Scan your computer with RadarSync and install the updates.
I hope this helps!
David
White screen problem on my netbook gateway lt2016u
I Got lt2016u/LT20 Gateway Netbook I need help restore my net-book and i need please restore it cause it got blue screen and keep going to slow and poping up errors messages PLEASE PLEASE help
2answers
Windows could not start because file is corrupt or missing \windows\system32\config\system this for gateway LT2016u Notebook and it has no setup cd-rom to start repair what can I do?
hard drive is shot
you will need to replace it and purchase a cd windows program from Gateway.com for you model computer. I had to do this and the cost was under $25 least year
As sson as i power on my gateway LT2016U the is csreen requests a password. I can get to the the re_boot or system steup menus?
power off laptop........ (this is your laptop you are the Administrator?) yes.....ready power on .... while this is booting up press F2........ you want to get to BIOS screen (note press quickly this has to happen real fast). once the BIOS screen is up use the up/down left/right arrows to navigate....... there are four / five tabs (screens) you are going to disable the password that is on the hard drive.... (on the third or forth screen (tab))... some laptop bios have 4 and other have 5 (4 or 5 being where you can save and exit).... now using the arrows to navi disable all passwords (you can always re-engage) now save and exit, system should re-boot and hopefully bypass the password......... enjoy
2answers
Have gateway lt2016u, i need to know how to take it apart
remove battery and all screws on bottom including the three screws in the battery compartment turn over and starting in the top middle of keyboard ( abvove the f8 key ) pop keyboard up remove keyboard cable and lift away keyboard remove all screws from under keyboard and up plug the two cables lift top cover off you now have access to all inter parts
Grand Canyon Tech
Grand Canyon Tech
