Televison & Video Logo
Question about LG Televison & Video
Hi, I have an LG FLATRON TV model m2362d. The problem is the remote and the tv buttons are not working and also showing a white box up the top with the numbers V3.02.0..Just a white screen..no channel
The only way to turn the tv on is at the power switch on the wall..Once turned on I get a white screen with a box up the top that moves left to right with the numbers V3.02.0 in it..The remote and the buttons on the bottom of the tv have no effect or function at all.Any help appreciated.
Posted by markyz1990 on
Harrison Spear
I have no remote control for the tv as I lost it ages ago and non of my home tv remotes work with it ??
Posted on Sep 15, 2021
5 Related Answers
Anonymous
SOURCE: Hi. I hvae a LG
Press the "Exit" button on the remote control and all will be solved!
Posted on Nov 23, 2010
Anonymous
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
Anonymous
SOURCE: Acer AT3201W LCD TV
I repaired my Acer by replacing the power supply from
http://www.power-on.com/lcd323-4m.html - $85
Acer would not sell me a replacement power supply.
Note: I needed to solder wires the new power supply to the old one,
the pinouts on the connectors on the new one would not fit the original.
Posted on Dec 13, 2008
Anonymous
SOURCE: Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Anonymous
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
Marvin
Marvin
