Question about OKI C Office Equipment & Supplies
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
Posted on Jan 30, 2010
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Posted on Mar 29, 2010
SOURCE: OKI C6100 has the following error when printer is
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
SOURCE: OKI image drum issue
Try this:
1) Power on printer while holding both the + & - buttons simultaneously; release when "Okiuser" is displayed.
2) Press + or - until "Engine Diag" Mode is displayed; press Enter and Diagnostic Mode xx.xx.xx will be displayed
3) Press and hold both Enter & On-line simultaneously until Eng Diag Level3 is displayed
4) Press + or - until Local Parameter Set is displayed; release and press Enter
5) Press + or - until it displays Factory Mode; if it displays Factory Mode Twice with an asterisk next to one then it is in Factory Mode; Press Enter, Press + or - until it displays Factory Mode & Shipping Mode on the display; then press and hold On-line & Cancel simultaneously; when it stops blinking an asterisk should be displayed next to Shipping Mode, which becomes the default mode.
6) Power printer off then on to complete the procedure.
SOURCE: My OKI priter says replace
drum is different then black toner you have to replace drum not toner
Posted on Jan 27, 2011
Jan 12, 2014 | Oki Electric Industry B411d Printer
Feb 07, 2013 | OKI C5100n Laser Printer
Jan 15, 2013 | OKI C5500n Printer
Mar 07, 2011 | OKI B4350 Laser Printer
Feb 10, 2011 | OKI C6100n Laser Printer
Jun 28, 2010 | OKI C9300 Led Printer
May 26, 2010 | OKI C5150n Led Printer
Dec 10, 2009 | OKI C9600hdn Laser Printer
Jun 08, 2009 | OKI C5400 Laser Printer
Sep 18, 2008 | OKI Office Equipment & Supplies
525 people viewed this question
