Question about John Deere Garden
John deere 14.5hp won't move after Put in gear after sitting all winter
Tractor will move in neutral but, when I put it into gear, it won't move.
Posted by ray lininger on
mike butler
    Brigadier General:
  • 6,468 Answers
The belt fall off?
Posted on Mar 30, 2012
5 Related Answers
Anonymous
SOURCE: in neutral cannot move tractor, rearend acts like its locked up
are you sure the parking brake is releasing
Posted on Mar 25, 2009
Anonymous
SOURCE: john deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Posted on May 05, 2009
Freddyyesme
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
Mike Squire
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
Anonymous
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
John Deere lawn tractor
Here's the link and I'm sure you will get the solution of your problem -
Best Manuals
Aug 30, 2018 | John Deere Garden
John Deere 3203 will start but dies when I put it in gear
There is usually a switch that only lets you start motor when in neutral. Now if that same switch opens when you go into gear that will cut off the ignition. Check it out.
Oct 07, 2015 | John Deere Garden
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
I have a 1999 John Deere LT-133 when I put it in any gear or try to engage the blade the engine won't stay running. Do you have any solutions for this?
sounds like the safety switch under the seat may be bad. unhook and / or bypass the switch. if this fixes the problem then replace the switch. hope this helps you
Aug 16, 2011 | John Deere Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Have a 2010 john deere probably a 60s. pulled it out of the blackberrys after sitting for about 15 years.got it running and hydro working, but i can put it an any gear and nothing. no grinding or any...
you may want to check and see if the gear oil is still good or if it has leaked out if it did or if the oil is bad change it but make sure you fix any leaks..good luck
Mar 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
423 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
