Question about Lexar Electronics - Others
How do I copy a saved letter, saved to my documents on to my jumpdrive so I can take to to get copied?
I need to copy a letter I have saved to my documents on my jumpdrive so I can take it out to get printed. i just got the jumpdrive and have never used one before; it is plugged into my latop...what is the next step?
Posted by darcy norlin on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lexar Master
  • 102,366 Answers
Open your favorite file manager (on Windows you can press the Windows and E keys simultaneously to bring up Explorer). Your jump drive will show up as a removable hard drive. You can then drag&drop your documents to it, the same way you copy any other files from one place to another.
Posted on Mar 30, 2012
3 Related Answers
JulesPCaut
Jules Peters
  • 702 Answers
SOURCE: how to save my documents to lexar 2gb jumpdrive
You can simply drag the My Documents to the drive, that will make a copy. But you could also use the backup function of Windows (simply type 'backup ' in the Windows help and follow instructions).
Jules
Posted on Mar 02, 2009
Anonymous
SOURCE: Please show me step by step on using the Lexar 2GB
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
Posted on Jun 20, 2009
Azrael SRL
  • 11800 Answers
SOURCE: jumpdrive states full but is not
File system error - format it the slow way in a different system.
Posted on Jun 15, 2010
Testimonial: "yes, did it and it works fine. i did run a virus scan first and then copy files before reformatting."
I want to transfer music from one computer to another using Lexar jumpdrive s5032 gb. How to do that
Upload the files to the jumpdrive. Remove jumpdrive from computer 1 and insert in computer 2. When computer 2 recognizes the jumpdrive, copy the files to a directory folder where you want to save the music. Unplug the jumpdrive.
May 13, 2015 | Lexar JumpDrive S50 32 GB USB Flash Drive...
Won't print large font in solid black. Only prints outline of letters in black
Try resetting word to factory settings to clear all the settings, Then make a new document and type whatever you want with the font size you require, save then print, see what happens.
Mar 10, 2015 | Office Equipment & Supplies
How do I get my document back from Lexar 8GB JumpDrive TwistTurn - USB Flash Drive
Hi Sarah... We will need to know a few more specifics before any information can be given to you. What program where you in, and what type of document were you trying to save. If you were in Microsoft Word, you can go up to the "file" menu, and look for "recent items". At that point, you would be able to open the document that you were working on, and then save it to your location of choice. What you might find simpler in the future, is to simply save documents to your desktop, and then drag them to the flash drive directly from there. At that point, you will have the document both on your desktop and the flash drive, and you can then take the documents it is still on your desktop, and move it into your documents folder...
Jun 02, 2014 | Lexar 8GB JumpDrive TwistTurn - USB Flash...
How do i use a memory stick on computer
An example on how to safe documents , photo's or data to a usb drive Click start all programs accessories open windows explorer navigate to your photos
Right click on the documents , photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
If you need more help with this post a reply
Mar 21, 2013 | Lexar LJDS70-16GASBNA 16GB JumpDrive S70...
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
Not able to scan and print as like copier
When you use a regular copier, it doesn't save, right? It just copies. That's the whole idea behind the Copy program that came with your scanner - for your scanner to operate as a copy machine. What you want is document management software.
Therefore, the very best solution is to download a (free) program that will convert files (Word, Excel, etc.) into PDF files. Click here for a list of such programs.
Suggestion: Never use image files for document management because they don't have any of the necessary features, such as the ability to search the contents of a digital document, the ability to comment, etc. And you want a program that will convert into PDF - try to stay away from other file formats as PDF (Adobe) is the "standard."
Mar 12, 2009 | Umax Astra 3400 Flatbed Scanner
How to save my documents to lexar 2gb jumpdrive
Jules
Mar 02, 2009 | Lexar JumpDrive Classic Portable USB Data...
Printing old copied images not saved
go to the printers & faxes documents & look for your printer model, now see if there is any pending documents there & delete it.
Feb 03, 2009 | Lexmark X2500 All-In-One Printer
Need to download a Microsoft Word article from XP system to a memory stick
Usually you just put the memory stick in the back of the computer in a usb drive, wait for it to load up , then you have multiple  options.
First you can go into word and save it directly to the jump drive... this is doe by selection "my Computer on the sleft side of the save prmpt then finding the jump drive.
Second you can save the file to a known location like the desktop then right click the file and click "send to" and findyour jumpdrive it should be at the bottom.
Or if it is already saved to a specific location, like "My Documents" just right click your start button, clcik "explore" then on the left pannel got to the location it is in and click it, then on the right pannel find your file and copy it "right click then copy", then on the left pannel find your jumpdrive and click it then on the right panel right click and hit paste.
hope this helps.
Dec 05, 2008 | Computers & Internet
I have a lexar 1 GB jumpdrive secure 2 plus and was using it to save pictures. In the middle of trying to save a picture a notice came up saying i couldn't save it because the directory was full. how do i...
In that case I have two suggestions. *note I am assuming you are using a computer with Microsoft Windows.*
One: Defragment the jump drive. With the jump drive plugged in click on the 'start button' and choose 'My computer'. Then right click the jumpdrive and select 'properties' which will open a window. Click on the tools tab and select defragment.
Two: Format the drive. First, if the drive will allow, copy the data fron the jumpdrive to your computer. Then click on the 'start button' and choose 'My computer'. Then right click the jumpdrive and select format. Let me know if you have already tried this or if you need more clarification.
Hope that works for you.
-WN
Aug 13, 2008 | Computers & Internet
Electronics - Others Logo
46 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
John Waters
John Waters
Damon Nesselrodt
Damon Nesselrodt
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
