FYI, Canon inkjet printer class action suit
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
SOURCE: Hi there , my canon MP630 has all of a sudden 6c10 error ?
That error says that either something is jammed in the purge assembly, the unit on the right that cleans the printhead, or the purge assembly is stuck or broken. If you unplug the printer with the carriage in the center you can use a flashlight to inspect the area on the far right where the printhead parks.
SOURCE: Canon Pixma MP600 - Error Message U052 ... incorrect print head
U052 mean the FINE cartridge may not be install properly,or the Cartridge may not be compatible with this machine.Install the appropriate FINE Cartridge. If lines are misaligned or the resulting out put is not satisfactory carry out the FINE Cartridge Alignment.
SOURCE: My Canon MP630 has a 6C10 error
You have a "Valve Cam sensor error". Usually caused by paper debris inside the printer, probably near the purge unit.
Have a ggod look inside and see if you can see any bits of paper.
SOURCE: My canon MP610 shows an error message U052 Incorrect print head
http://www.buzzillions.com/review/canon-pixma-mp610-multifunction-photo-printer-review-2458903?prRo=0&reviewSortBy=mostHelpfulFirst&prRpp=1
you wont like what you find. lol .
apparently if you call cannon support they going to tell you its a U052 is a temperature sensor error. and not the print head error. someone musta did some bad programming. lol
try returning the cartridge if its not a canon specific cartridge - and get replacement - try that - but i doubt its going to work - i would call about a new one (print head that is - they will also apparently send you a new print head.) as i have read up on
hope this helped
x404x
Testimonial: "Thanks for your quick response - I thought there was a resetting tool available so I can at least remove the message and get printer going."
