I have had the tablet for 3 months, was working fine but failed to connect to the internet through wifi a couple of days ago even though there was a good signal. I checked the settings, the wifi is on but the bluetooth is off and will not switch on. I took the tablet back to factory settings but still no connection to the internet through wifi and still cannot turn the bluetooth on. thank you
SOURCE: Dell Laptop WiFi Connection
Right click on the WiFi icon on the taskbar, select "view available wireless networks".
Then right click on change order of preferred networks
If the "Use windows to configure my wireless" is unticked, tick it
From the list below select the network you are trying to connect to and remove it and press OK
Then right click on the WiFi icon again and Vioew available networks and try to connect
SOURCE: WLAN switch button does not work
Locate your wireless card compartment on your computer. It is probably on the back of it. Your computer manual should tell you where it is. Open the compartment and locate your wlan card. Remove it from your laptop for about 30 seconds, and then reinsert it and make sure that the proper connections to it are firm and secure. Close up the compartment. Turn on your laptop. Your laptop should search and recognize it. If it doesn't, then your wireless card probably quit working on you. If your computer is still under warranty, and if it doesn't recognize it after you have tried this, then you can contact your computer manufacturer and explain to them what happened. They should replace your wireless card at no charge. If you bought the wireless card from some other store, then take it to them and explain to them, and ask for a replacement wireless card.
SOURCE: Wireless internet is not working after restoring factory settings
Oh, wireless Internet? You restored it? Did you install a different operating system? Or had you installed one before resetting? A change of OS may result in the deletion of particular drivers.
Go to the manufacturer's website. There, search for your model's support and download the drivers you want, for instance, the wireless network adapter drivers. Also, check your sound.
SOURCE: wireless switch won't turn on
reinstall the driver and test it ,if dosent work the black bottom is gone from its place ,or its switch is damaged and you must open the front case and fix it.
SOURCE: Acer D150 Netbook - I get a good WIFI signal but
go to my network place then go to local area connection logo and right click on it then go to propeties after that u will see a window crew down to TCP/IP once u are thr click on properties to ur left then fill in the code after than click okay and make local area connection your default connection. thats it u are done
