My Wi-Fi on Lenova Think Pad T60 is not working. I tried to update the drivers. Still not working.
I am trying to connect to home wi-fi but the note pad's wi-fi does not work. I downloaded the driver updates and still have the problem.
Posted by Luke Taylor on
  • Brad Brown Mar 29, 2012
    The first thing that you need to do is tell what operating system you have on it.
General Systems Consulting
    Top Expert:
  • 5,051 Answers
What is it doing? Still not working could mean a lot of things!!! Is the computer connected to the wireless network? You've got to connect to the network before you can do anything. And most times the problem with connecting to the network is people key the network key or password wrong so the wireless just keeps on polling trying to connect.
Do you have the wireless turned on on the notepad? Sometimes there might be a wireless switch somewhere that you have to turn on. Also most times you can toggle the wireless On and Off by hitting the FN Function key and the corresponding F1 thru F12 key that toggles the wireless. Most times the correct F1 thru F12 key will have a wireless icon signal on it sorta like ))))) or it may show a tower with the signals. Once you find the correct F1 thru F12 key to press then Press and Hold the FN Function key then hit the correct F1 thru F12 key. If you look at your screen most times it will let you know if you've toggled the wireless by displaying Wireless On or Wireless Off.
Posted on Mar 29, 2012
5 Related Answers
boopar khoo
  • 55 Answers
SOURCE: can't download compaq 754 tu laptop wi fi drivers
Hi
Try this link:-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3674870&lc=en&cc=us&dlc=en&submit.y=10&submit.x=2&lang=en&cc=us
Posted on May 20, 2008
Anonymous
  • 327 Answers
SOURCE: problem with wifi driver for acer aspire 4715z
Welcome to fixya
try going to driversupdate.org and see if you can down load there program and try to run it ....it helps alot on the driver updates and things like that and it is easy to use
hope this helps out have a good day
Posted on Jul 22, 2008
Al42
Al Klein
  • 72 Answers
SOURCE: Toshiba Tecra A3-S611 Freezes
If by "turned off" you mean with the switch, the wireless adapter itself is probably bad.The cheapest solution is to buy an external wireless adapter.
Posted on Sep 10, 2008
Anonymous
  • 287 Answers
SOURCE: DRIVER PCI MODEM & WI-FI FOR NOTEBOOK A*NOTE MODEL CL51-14
search it with ur model no. on Google Serach !
Posted on Jan 07, 2009
Anonymous
  • 56 Answers
SOURCE: wi fi driver
Hello, most common Wi Fi- Adapter for your notebook is:
Intels Pro-Wireless-2200BG
download driver here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637
Posted on Apr 30, 2009
How do I find Wi fi passwords?
Hi Andrew, If you're trying to connect to your home Wi-Fi The password in on the back of the modem, Write it down then go into your phone/tablet settings and click "CONNECTIONS", Then click on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens asking for the password, You're connected... Bellow is a link to a short youtube video explaining pretty much the same thing..... I hope this helps...
https://www.youtube.com/watch?v=8XurHgNoZhs
Mar 30, 2016 | Tablets & eReaders
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
My I-Pad will no longer connect to WI-FI. Any suggestions?
Take to "Genius Bar" in Apple store; they will Dx for free; only charge if repair is necessary!
Sep 27, 2014 | Apple Ipad I-pad
Is there any way to get a better wi-fi single
Some of the very common causes of poor Wi-fi reception include- the Wi-Fi router is placed too far from the device on which the Wi-Fi network is being accessed, too many devices are connected to the Wi-Fi network simultaneously, or Wi-Fi settings are incorrect either on the router or on the device which accesses the Wi-Fi network. There are many more reasons that can hamper your Wi-Fi connectivity.
You can refer to the following links to understand the issue you might be facing and to find a suitable resolution for the same:
(Important: Following links are of third-party websites. Hence, we recommend you to update your security software thoroughly before accessing the links. Also, avoid accessing a webpage if its access is denied or a security warning is issued by your Windows or security software.)
(Important: Some of the resolutions mentioned in the following webpages may be technical in nature. We recommend you to try only those resolutions that you find convenient to execute. Take professional help wherever necessary.)
http://www.wikihow.com/Improve-WiFi-Reception
http://www.pcadvisor.co.uk/how-to/network-wifi/3428611/boost-wi-fi-signal-get-faster-wi-fi/
http://lifehacker.com/5931743/top-10-ways-to-boost-your-home-wi-fi
Hope this will resolve your issue.
GuruAid.com
Jul 24, 2014 | Computers & Internet
Connect to ipad
You don't assign an IP address to your iPad, it has one assigned to it by your router.
Open the Settings app on your iPad. Make sure Airplane Mode is OFF. Tap Wi-Fi. Make sure the Wi-Fi switch is ON, Ask to Join Networks is ON. Your in-home wi-fi network should be visible in the list titled Choose a Network.... Tap its name and provide the network password required by your router.
If you don't see your local router listed, it may not be properly configured.
Mar 10, 2014 | Tablets & eReaders
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
MY SONNY ERICSSON X8 WHY I CAN'T GET THRU IN WIFI
To connect to a WLAN via Wi-Fi™:
  1. From the Home screen, find and tap Settings.
  2. Tap Wireless controls > Wi-Fi settings.
  3. Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are displayed in a list under Wi-Fi networks. The available networks may be open or secured. This is indicated by the icon next to the network name.
  4. Tap a Wi-Fi™ network to connect to it. If you are trying to connect to a secured Wi-Fi™ network, you are asked to enter the security key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™ connection is displayed in the status bar once you are connected.
Useful tip:
  • The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
  • To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
  • To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
  • To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networks section.
You can also try updating your softwares by going to the sites below;
Update Service,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=en
PC Companion,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax8?cc=gb&lc=en
Start the program and just follow the on-screen instructions.
I hope this will help.
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
74 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
