The projector light won't come on and the power and temp light are on, the smart board show a green light
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
SOURCE: hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
SOURCE: hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Products/SupportServices/Support/DiscontinuedModels/index.html&level=4§ion=Products&parent=DiscontinuedModels&nav=left&path=jsp/hitachi/forhome/DisplayTechnologiesGroup/
SOURCE: Hitachi CP-x430 "Check air flow"
I have run in to this time and time again. This is why I like to keep things clean. take the bulb out and blow the unit out with air and make sure you wipe off what you can with Q-tips The blub allows air to flow thew the filament so what ever dust that might touch the fillament while its burning will burn at a higher temp. this will send and indication to the unit to send a message that says replace bulb soon and If there is not enough air flow it will say CHeck air flow take the fliter out and clean it with water dont replace it. IF you do just buy a carbon pad and cover the hole(not recomended foir those who are not handy) but keep things clean and it will save you $ in the long run. How many bulbs do you want to buy?
