Engineers have been twice and got it going, 1) blew down the overflow pipe and removed a blockage. 2) cleaned out my condenser. Then leave and it stops draining again. All pipes are clear and filter. I've had E33, E22 and E20 errors each time it stops again. This time all the hose-blowing and hand draining doesn't seem to get it going again.
SOURCE: machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
SOURCE: My AEG lavamat turbo 16810
I'm not sure if this model has an access panel with 2 screws at the bottom, but if not, An easy way to access is by tilting the washer against the wall and removing the bottom panel, Should be 4 screws. from there you can remove the hose and retrieve the debris from the pump most likely change. have a fairly good size bowl and towels close by to catch the water. make sure the washer is disconnected from it's power source. Hope this helps.
SOURCE: Lavamat 74640 - wash cycle
Hi Andrew from retired Englishman in SW France,
(No- I don't type very fast; most of this I've pre-typed!!!)
It could be that the drain motor/pump itself is blocked/jammed.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
