Remove the batteries for 60 seconds to clear the microprocessor ic and press power and hold for 60 seconds to remove residual voltage. Now re-install the batteries, if there is no change the systems control board is the problem, cheaper to replace the camera.
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Force the phone to shut down and reboot.. Hold the home button and power button at the same time for at least 10 seconds wait for a few then turn it back on as normal.
I have had a similar problem. My solution was to check the zoom button. It seems that when it is "out of range" you can do nothing with the camera. Try to adjust the zoom a Little bit and you will probably be "in range" and the camera with work.
hi wendy, I have the same model tv and it has been doing exactly the same problem you have ever since buying it (2007 - 08) and every time it does freeze it seems to be on channel 9. The only way i overcome this problem is to turn the tv off at the wall for atleast an hour and turn it back on and it seems to re-set itself or should i say the built in set top box re-sets itself and it works fine for a few months and bang it does it again. Apparently there is a LG software update but only technicians can install this. Anyway thats my story! :)
R09 or R07 etc. is not an error message. In Nikon lingo ERR is the one you need to worry about. The RXX refers to the approximate amount of shots left in the buffer in the camera. Not a ptoblem. You may be trying to take pictures faster than your memory card / camera buffer can handle.
You can try a fster card like 266, but you may find that the camera is also your limitattion.
If you make no changes at all, the camera buffer will eventually clear and you can again takes pictures.
You gotta put your installation cd into the computer and install the Sansa Media Converter. That will put all the pictures and videos on the mp3 player. To get it "unfrozen" just press and hold the power button for 15 to 20 sec.
