Question about MTX JackHammer JH600 Car Audio Amplifier
Car amp not working
Amp is hooked up correctly and played fine. Amp suddenly stopped working and now has voltage going through speaker wire. Has anyone ever seen this problem before
Posted by Troy... on
Anonymous
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Is amp getting power or not could be wires came loose inside speaker box
Posted on Mar 30, 2012
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Posted on Aug 08, 2007
iqbal ibrahim
  • 41 Answers
SOURCE: Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Posted on Sep 11, 2007
Anonymous
  • 505 Answers
SOURCE: the red light on my amp keeps coming on and it wont work
Sounds like you blown it mate
Posted on Jul 18, 2008
Anonymous
  • 125 Answers
SOURCE: when i hook up my amp. i have all my wires hooked up right,
this is a signal crash either your speaker wires are crossed (wrong wiring phase) or your RCA jacks need replacing also it could be inside your amp the solder lines may have fused. If after checking and replacing wiring problem persists return to MTX for repair.
Posted on Feb 04, 2009
Anonymous
  • 655 Answers
SOURCE: i have a mtx thunder 1501d..i have the power cord
Hello tonytone54, The ground should go directly to the vehicle frame, never through a cap, fuse, or anything else. Also, if you are connecting positive through a cap, make sure that you charge the cap before connecting it. Hope this helps.
Posted on Jun 03, 2009
Amp playing speakers very quietly
it sounds like you have the polarity of the speakers hooked up wrong on one of them, try unhooking the new speakers you added and hook them back up one by one, when the music gets fuzzy then reverse the wires for that speaker, this should cure your problem.
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
1helpful
2answers
My pyle amp keeps going into protection when i turn my music up and play it for a min
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
Red protection light
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
1helpful
Amp stoped working
You need to run a larger power/ground cable. If you are reading low, you are not getting the kind of voltage that the amplifier requires to run, you may have been fine before adding the other products but if you wired them all to the same power wire (say an 8 gauge) you'd encounter problems. You should probably use a 2 gauge or at least a 4 gauge power kit.
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Amp cuts off...
Are the woofers single or dual voice coil?
How many ohms per coil?
If they are dual voice coil, are the coils for each speaker wired in series or parallel?
Are the speakers connected directly to the amp or are the speaker in series (one wire from each speaker connected to the amp?
Have you checked the DC voltage at the amp when you're playing it at high volume (where it cuts off)?
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Amp not working
1. Did you witness this amp ever working if not then you may have a blown amp. Hook up the speakers, get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If sound comes out then your problems are elsewhere. If not I'm afraid your amp is probably toast. If the OHM rating of the speakers are too low for the amp then the amp will go into protect. This will be indicated by the protect LED lighting up or the power led changing color from say green to red.
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
MTX JackHammer JH600 Car Audio Amplifier Logo
Top MTX Car Audio & Video Experts
Pierre Laplante
Steve Sweetleaf
Steve Sweetleaf
 Francisco Mauricio...
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
