When i push the cel right buttom it doen't turn on, but sometime appears LG logo on screen, that set. I changed the main board and it works properly. The problem is in the main board so where i can buy new one, or refurbished?
You can buy all sorts of cell phone parts on ebay. Are you sure you have a fully charged battery in your phone? If the battery is charged, and the phone will not boot past the welcome screen, you will either need to do a hard reset to reinstall all of the operating system files or replace the motherboard. Do an internet search for LG KP500 hard reset for detailed instructions for the hard reset. Caution - this will delete all files which were saved on your phone. It will not delete files on your SD memory card.
SOURCE: lg kp500 hangs on logo screen - will not start up
my LGkp500 wont go past the start up logo how do i fix it.
SOURCE: changing wallpaper on samsung f 480 main screen
YES YOU CAN CHANGE THE MAIN SCREENS WALLPAPER. sIMPLY TRANSFER ANY BMP OR JPG FILE INTO YOUR IMAGES, THEN SIMPLY SELECT MENU, MY FILES, IMAGES, TOUCH THE IMAGE YOU WANT TO USE, SELECT OPTIONS, SET AS, WALLPAPER. OR GO INTO THE SETTINGS CHOOSE 'DISPLAY AND LIGHT SETTINGS', 'DISPLAY SETTINGS', 'WALLPAPER', 'IMAGES', THEN JUST SELECT THE IMAGE YOU WANT AS YOUR WALLPAPER.
HOPE THIS HELPS
SOURCE: lg kp500 (cookie) has broken!
swap the sim if that dosent work take it to a phone shop that will unlock that for you if it doesnt work get a new phone
SOURCE: lg cookie kp500 wont stop
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
when i tried to turn the cell on it does't , sometimes turn on and shows the logo brand and stays in this status. could be te operative system?
