I put my mp3 on the charger and let it sit overnight but when i unplug it the mp3 says low battery and cut off
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
SOURCE: Zen v wont charge
http://www.anythingbutipod.com/forum/showthread.php?t=10960
If that doesn't fix it try the USB cable
SOURCE: RCA MP3 M208 won't hold charge -- Only about a yr old
either the battery pack itself is bad, or the ribbon connection cable that attaches battery to main circuit board is faulty, broken, or loose. It is common.
SOURCE: my gigaware mp3 has a full battery charge but wont work
Slide the unlock bar on the side of the mp3 player. It is on the left side of the player.
SOURCE: 2g black mp3 player not holding charge
Your mp3 player seems to be malfunctioned or damaged from inside give it for repairing it will help alot..!
Thankyou. :)
SOURCE: I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
