Gains 15 minutes every time- I reset it 2-3 times a day
SOURCE: My laptop says Time -of -day clock stopped when i turn it on
It sounds like the battery on your computer is dying, and the battery cannot keep the clock running. If Dell's warranty is still valid, contact Dell, to get your computer fixed/replaced.
SOURCE: my compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
SOURCE: Turn on my Dell Vostro 1500 and all I get is a black screen
Remove and re-seat your RAM cards. Remove your battery but leave the power supply attached. Try to start. If this doesn't work, your motherboard has died and needs to be replaced. Not a do-it-yourself job unfortunately.
SOURCE: My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
SOURCE: time of day clock stopped - DELL Inspiron 1525
This is one of the known issues with the Inspiron 1525 computer.The problem is caused by faulty cmos battery. If you computer is in warranty kinldy call Dell to get the same replaced . if the system is out of warranty. You would need to replace the CMOS battery ie below the keyboard.
You can follow the instructions below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/coinbatt.htm#wp1179839
Thanks
Proton
