Question about HEWLETT-PACKARD HEWLETT PACKARD HP COLOR LASERJET CP2025DN Duplex Unit
HP Color Laserjet CP2025dn manual feed tray one not working
The manual feed ("Tray 1") on my HP Color Laserjet CP2025dn is not working.
Posted by ckboeckman on
Nor Sairi
    New Friend:
  • 24 Answers
Mybe your pickup roller problem.
Posted on Apr 01, 2012
1 Related Answer
let me help
sheraz Gul Bar
  • 196 Answers
SOURCE: I have a networked hp 2025dn printer the problem
my personal opinion is that you might have two basicproblems
1.open the lid from back of your printer, you may see a stiff film .,give aprint command and check the film rolling visually , if its broken then it mightgive you annoying sound like something's broken , but it can only be visualizedgiving a print command ,
if its really broken from edges it may give you this problem, it can be fixedby local service center ,I had this problem it cost me about 2.(clean your printer ) >Open printer >remove the toner > check for any piece of stapler pins or any paper or anyother waste that's stuck in between drums. > if you have a wind blower machine blower it . > must keep in mind to blower it in open area, causeblack particalls will make you cough, or would get dusty, 3. your toner must have ink dust at one side, shake thetoner and then insert in printer , this will help you . I hope it helps you
Posted on Mar 29, 2011
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
Color laserjet 3600 ghosting from tray 1 manual but tray 2 work fine
Check the paper setting for tray 1, sounds like you have the wrong settings for the type of paper you are using. For instance, if you are feeding envelopes and have paper type set for plain paper then the printer will not bond properly.
May 09, 2011 | HP Office Equipment & Supplies
Does my printer have a "Manual Feed?"
Yes. The manual feed tray is in the front door with the HP logo on it. When you fold that down this becomes the manual feed tray. Also note that HP referes to this tray as Tray1. The bottom paper tray is tray 2.
Thank You for using Fixya.
Dec 01, 2010 | HP LaserJet P2015dn Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jul 23, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
May 05, 2009 | HP laserjet Cp2025dn color Card Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
HEWLETT-PACKARD HEWLETT PACKARD HP COLOR LASERJET CP2025DN Duplex Unit Logo
417 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
