SOURCE: very grainy playback
This is typical symptom of a dirty video head. this ahappens especially if you play a tape with molds. Cleaning tapes may or may not work. the effectiveness is based on: 1. If the contamination is severe, sometimes the dirt really sticks to the head. You will not normally see this because the head is the tiny part on the head drum that spins. 2. If you use a non original head cleaner 3. If you re-use a tape cleaner. I had this problem on my Sony Hi8 camcorder, i had to mannually remove the dirt on the tape head. I will not recommend to do it as it may damage the head. What I would recommedn first is to buy a Sony head cleaner, and try to clean the head. You may try more than once, it will not damage the head right away. If this does not work, before you send it for repair, ask for estimate. Maybe it is cheaper to buy an analog Hi8 player on ebay rather that send it for repair. And BTW if you have a Hi8 camera, it can play both video8 and Hi8. If you have a video8 camera, it wont be able to play Hi8.
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: Sony Handycam DCR-TRV460 Digital-8
Camera has dirty / clogged video head.
Use good quality video head cleaning cassette.
SOURCE: Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
SOURCE: Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
