Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Temperature sensor warning on konica bizhub 350
Copier is giving me a temperature sensor warning
Posted by charles huss on
just me
    New Friend:
  • 60 Answers
Provide the code please
Posted on Apr 14, 2012
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
steven brickhouse
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Anonymous
  • 143 Answers
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Posted on Aug 26, 2008
Anonymous
  • 167 Answers
SOURCE: Konica Minolta Bizhub 350, for faxing on Windows Vista PC
Yes you need the Driver.
http://help.bt.konicaminolta.ca
You can find all the drivers and help you need there.
Posted on Aug 29, 2008
Anonymous
  • 300 Answers
SOURCE: Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Posted on Sep 02, 2008
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Apr 14, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
How to reset bizhub 350 to factory settings
why to factory setting? problem with memory? code or certain problem?????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 02, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub 950 report code c-3503
Fusing high temperature abnormality.Check the connections and the relevant electrical components(thermistors,thermofuses,heater lamps).
Dec 12, 2013 | Minolta bizhub 350 Black and White Copier
My Bizhub 350 is saying malfunction dectected C3452
This code means you have a fuser warm up failure. The fusing unit uses heat and pressure to "fuse" the toner onto the paper. It is located right where the paper exits the machine. Here is the info directly from the service manual:
The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Most likely you have a thermistor failure in the fuser. You are going to need to call your local service company and have them repair then reset the machine.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
Mar 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 error code
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
66 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
